Anwer
- Apr 30, 2014
Is it unrecommended to use TRRS plugs on the Mojo?
Hi Peter,
According to their marketing material Audirvana+ will sound better by using iZotpoe 64 processing instead of Apple's own Core Audio. To be honest I really haven't compared the difference with the Apple Core Audio output. I just wanted a program that would integrate with iTunes (an interest for me at the time, but no longer), has its own quality library feature (which Audirvana+ does), and something that can read and pass along the native bit depth and sampling rate of the file. The icing on the cake is the robust EQ and audio effects that can be used in Audirvana+.
I think it's definitely a worthwhile program. Try it out, I think you'll like it. You've got nothing to lose.
Could please someone compare Mojo in standalone doc mode to other days? What is the quality and how do you compere it with giving other brand names. Than you very much an I appreciate any help.
The downside about A17 is the cable walkman to micro usb.
It eats battery A17 faster.
But I don't care as long as Mojo Wow me everytime.
Thanks. I see its use of iTunes, but is it worth it if I am subscribed to Tidal "Hi Fi"? (other than EQ)
