If you are wondering how these adapter is being wired, they are taking the left and right signal from the different 3.5mm output. Doing it this on paper minimise the interference (crosstalk).
I am going to leave the sound impressions alone, I know a lot of people believe everything has a sound, I don't
However, I think the bold part I copied above is technically inaccurate.
In the Mojo the two 3.5mm jacks are connected to the same output from the DAC (and what little amp exists) and the adapter connects to the same two signal outputs and a ground regardless of how they are wired internally. It is literally just a different wiring set up connecting to the same place.
How can the cross talk change when the circuit is functionally identical ?
In fact the ddhifi adapter in the image above (I know that isn't the one you were referring to) connects all terminals of both 3.5mm jacks to the 4.4mm jack.
