Absolutely no problem at all running a Mojo 2 into a Vali 2++.Can I ask about the suitability of the Mojo 2 as a DAC only, feeding a separate headphone amp?
I've bought the Mojo 2 and I'm considering getting a small tube headphone amp (Schiit Vali 2++) and I was wondering about the fact that the output of the Mojo 2 is designed to drive headphones, not act as a line-level signal to feed a pre-amp.
I thought that the voltage and output impedance needed to be particular values, as found in a standard line-out such as RCA connectors, rather than the headphone amp output from the Mojo 2.
Is this not a case of amping an amp (which I've always heard is something that should be avoided)? Maybe @Rob Watts could give me some guidance if you have time?
I found this post which suggests that the output is actually not a headphone amp in the traditional sense but rather a high-level DAC analogue output so I should be fine.
Can anyone confirm?
I set the Vali 2++ on high gain adjust the volume dial to about 12oclock then increase the Mojo 2 volume.
It’s usually around the blue colour.
Then fine tune from there with the Vali 2++ volume dial.
The Vali 2++ is a fantastic cheap little amp.
Have fun tube rolling and check out the Vali tube rolling thread.
