Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Apr 29, 2023 at 10:37 AM Post #7,906 of 12,389
Oh yeah really. Easy as that. Hang on a minute #checks trouser pocket# No #checks jacket pocket# Great stuff I knew I had 500 quid somewhere. Get the DDhi fi lightning usb c cable, no issues this end for me.......
Which model iPhone do you have? Which DD hifi cable did you get?
Apr 29, 2023 at 10:49 AM Post #7,907 of 12,389
To those of you who got the Mojo 2 update or are thinking of getting it done, I made a video about my experience.
:L3000: Chibs
Great vid. Hope that was a cheap headphone you threw on the floor!😂
Apr 29, 2023 at 10:57 AM Post #7,908 of 12,389
Apr 29, 2023 at 10:59 AM Post #7,909 of 12,389
iPhone SE 3020
DDHifi Mfi09S
After watching the full video, I feel pretty lucky I’ve had a perfect experience. My last dac amp Shure SHA900 had pulsing white noise with my first iPhone SE, but not the second edition 2020. Go figure.
Apr 29, 2023 at 11:13 AM Post #7,912 of 12,389
Am listening to Steely Dan Aja. Yeah, the DAC on this unit is not surpassed by anything under 2 grand, you’re right!
Apr 29, 2023 at 11:15 AM Post #7,913 of 12,389
Pretty sure I have a different dd hifi cable. I may try this one and see what happens. Thanks!
Yours is different. Could tell in the video
Apr 29, 2023 at 4:16 PM Post #7,914 of 12,389
I've got some chicken soup spilled on my phone. That's what's causing my white noise issue....or maybe it's the cocaine...
Apr 29, 2023 at 4:50 PM Post #7,916 of 12,389
:L3000: Chibs
Thanks for the video update Chibs! I did the firmware upgrade with The Sound Organization in Texas because I was getting white noise with a 2020 iPad Pro (USB-C to USB-C) and M1 Max Macbook Pro 2021; I never had a problem with an iPhone 12 Mini (using CCK). The white noise was very rare for me (only if I moved the cable too much) so I wasn’t really bothered, but when I saw post about the upgrade, I said, “Why Not?
The white noise issue to me was very similar to the one I experienced (with many other early adopters) on the Lotoo Paw S2 when it first came out: move the cable too much and the USB chip lost sync and did not fail gracefully, thus producing a white noise at set volume until unplugged and replugged. When the Lotoo folks pushed the firmware update out (thankfully it was user-upgradable and not needing me to ship it halfway across the US) the solution seemed to be that if the USB lost sync, the music just stopped on the player and you just had to hit play again; like if you pulled a dongle out when playing music.
Well, that’s exactly how this fix for the mojo 2 is behaving: if I move the cable too much (which would usually cause the white noise) now just stops the music and I have to just hit play again.
Another interesting thing I learned from your video: you confirmed for me that they had to open the case. I suspected this since my Mojo 2’s case screws showed wear and tear and the top case was not my original one (my case had a big scratch in it and the new one was pristine, but the base was the same with the same serial number sticker).
Cheers
Apr 29, 2023 at 5:00 PM Post #7,918 of 12,389
Get a DAP with coaxial out to feed the Mojo, far reduced chance of white noise it seems.
Yes, a good option. I tried coax out of a FiiO M11+ LTD (OG AKM) and it was fine. But I also had no problems with USB out from the M11 either to the Mojo 2. So I think this is maybe an Apple problem (?). Anyone have the white noise issue on something other than Apple kit?
Apr 29, 2023 at 5:06 PM Post #7,919 of 12,389
Cheers
Interesting! Now I’m wondering if I should get them to update my Mojo 2 replacement. Thanks for sharing this.
Apr 29, 2023 at 5:08 PM Post #7,920 of 12,389
I use my original Mojo with FiiO M11 Plus LTD also, mostly with coaxial but also occasionally with USB which has also been fine.
I have had two white noise issues with my original Mojo and both were when I was A/B checking against other gear and was plugging and unplugging cables quickly. Never had a problem when just using it normally sitting on my desk with any source including an iPad mini 6.
