jarnopp
- Nov 26, 2014
It will hopefully sound better than white noise or static!I can see the flood gates opening.
How long before someone says the new chip set sounds better?
Mines going nowhere.I'm sending mine in even though I don't have the problem to get the Mojo 3 upgrade
Yes as I am in NA. Mine is going to Toronto. Texas for USA.So you must send the device back to the retailer in NA? Can I ask your Mojo 2 serial number?
Do you have the terrible white noise, if so it’s probably for you. They told me mostly M1’s and some Windows laptops but didn’t elaborate. Just contact support if you have the issue is my advice.Is this firmware patch to deal with M1 chipset in Apple devices only?
I got it on a Surface StudioDo you have the terrible white noise, if so it’s probably for you. They told me mostly M1’s and some Windows laptops but didn’t elaborate. Just contact support if you have the issue is my advice.
