Guy Fawkes
Explain to me the reason for your insinuationIt is obvious this device is not for you.
You've got the right one selected. Try sinc-L and sinc-LI as well. I use the following:Hi all, enjoying my Mojo 2 here as a Desktop DAC hooked up to my Mac HQPlayer on one end and a Schiit Lyr+ on another. Does anyone have their favorite HQPlayer filter settings that they can share? I am trying out Sinc-M, LNS15, 768k right now and it sounds really clear and resolving.
Do I need to do anything special to hook the mojo2 to an external amp ? I guess I only need a 3.5 to RCA adapter ? Any rec ?Hi all, enjoying my Mojo 2 here as a Desktop DAC hooked up to my Mac HQPlayer on one end and a Schiit Lyr+ on another. Does anyone have their favorite HQPlayer filter settings that they can share? I am trying out Sinc-M, LNS15, 768k right now and it sounds really clear and resolving.
Amazon basics works as well as any other.Do I need to do anything special to hook the mojo2 to an external amp ? I guess I only need a 3.5 to RCA adapter ? Any rec ?
I bought AQ 3.5mm to 2 RCA adapter then I use my regular HiFi RCA cables connecting to my ALO Studio Six Tube Amp....Do I need to do anything special to hook the mojo2 to an external amp ? I guess I only need a 3.5 to RCA adapter ? Any rec ?
The guy that designs the device answers you directly and you don't accept his explanation. My conclusion is that this device isn't what you desire in a portable DAC/AmpExplain to me the reason for your insinuation
I think you misunderstood me, or maybe it's me who didn't express myself well in English, contrary to what you say, i accepted Rob's answer and understood that he had to compromise.The guy that designs the device answers you directly and you don't accept his explanation. My conclusion is that this device isn't what you desire in a portable DAC/Amp
I guess the misunderstanding is mine to share alsoI think you misunderstood me, or maybe it's me who didn't express myself well in English, contrary to what you say, i accepted Rob's answer and understood that he had to compromise.
I hope it was understandable this time because to be able to express myself, i use the automatic translator and from Italian to English it could make some mistakes.
I love the Mojo 2 and the Poly and that's perfect for me, I would have liked this feature but that's okay.
Already exists - I mentioned Qudelix 5KA ten band parametric EQ that is also lossless? Yowza that sounds like a big job.
Hmm…lossless in the way Rob says Mojo2 EQ is lossless?Already exists - I mentioned Qudelix 5K
Obviously the analogue out performance of the Qudelix doesn't match Mojo2 but that wasn't the point.
Point was a better way to set EQ , for next product
I did say for the next Mojo3/Hugo3Hmm…lossless in the way Rob says Mojo2 EQ is lossless?
If they release Mojo3 without wireless I would never buy Chord products again.I did say for the next Mojo3/Hugo3
Rob can do Rob's lossless right ?
Nothing special, just find a 3.5mm to RCA adapter and run your standard patch cables to the amp. Attached some pics. Mine is an Audioquest right angle one. I think I got it from Amazon. Just need to set the volume to dark purple so you get about 3Volts out. Just depends on your Amp.Do I need to do anything special to hook the mojo2 to an external amp ? I guess I only need a 3.5 to RCA adapter ? Any rec ?
Did you try another cable? I am using the Mojo2 with my laptop, office desktop, iPhone, DAP for several days with ~5 hours per day but luckily I have not experienced this issue. I also owned Hugo2 and the classic Mojo before but never experienced this issue.Didn't take long for me to hear "white noise" with the mojo2 ... just by pressing the volume down button. Not a pleasant experience. Is there any trick to avoid "white noise" as much as possible ? I was using Android UAPP with a 12cm OTG cable that I took from my Hidizs DH80S dac.
