I don’t think it does. I mean the mojo 2 might go to desktop mode but the poly will not. Will be like you’ve left it constantly connected to power
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
vlach
I would also consider IEMs, very easy to drive and excellent isolation.Hello my friends, i have to share this with you.
Im 39 year old that never went to this Audiophile world, but always listen to music with causal/bluetooth headphones.
A few months back i start to think to upgrade the headphones and i went to this rabbit hole.
Last month bought a used pair of Hifiman Sundara. Last week i bought a used Mojo 2.
Yesterday i put all together, a month free Tidal app in my phone (synchronize the Spotify because the playlists) and fire all things up after the 5 years old son was assleep.
My wife didnt know that i start this new "hobby" and was by my side when i start to put some volume up in mojo2+sundara. Immediatly two things happen:
Well, i bought the sundaras because i can lissen to hear talk about something and still enjoy "some" of my music. WOMANS!!!
- My mind blown away with the detail of the music (i was lissen Gotan Project) with this combination (well i dont have anything beside cheap headphones to compare)
- My wife starts shouting at me because she can hear everthing and this "new" headphones are junk and they should be quieter and restrict the sound to myself
What should i do now?
If closed backs i will go full in this rabit hole and thinking in something like Audeze LCD-XC, how do they pair with mojo?
- Closed Back headphones
- Divorce
Do you guys have some advice to close backs and mojo2?
Thank you, sirs
- Divorce
Thank you, sirs
Get a good pair of IEM (earphones) and you can enjoy really excellent sound as loud as you like sitting right beside your wife and she won’t hear a thing.
Your Mojo 2 will power any IEM really well.
Side bonus, because they are small and discrete if you select sets that are not to visually distinctive you can probably buy half a dozen sets and she won’t even notice
In all seriousness, IEM are your answer for when you are around your wife and want to listen to music. I have been on a bit of an IEM thing over the last six months or so and have come to prefer them to headphones if comparing comparable quality sets.
rlw6534
But you won't be able to hear you wife, which can be good and bad....
A divorce gets you the same result... hopefully...But you won't be able to hear you wife, which can be good and bad....
glpsace
I would like to ask how many years of warranty is provided with the mojo 2 and Poly products in the European Union? 2 for sure but I'm hopping being positively surprised
Cheers.
Cheers.
Does the Topping HS01 do the same job as this Startech PCI-E USB-C card??If you run your Mojo₂ off a PC w/ PCI-E availability, I recommend looking into a Startech PCI-E USB-C card.
This will not only improve performance by introducing low latency hardware into the chain, but it will reduce noise floor as it will have it's own bus and power directly to the CPU.
Make sure you are using the same ASMedia USB 3142 chipset as the JCAT PCI-E card:
https://www.asmedia.com.tw/product/55AYQ83xg4uy6Uj0/0C8YQ4asx4yt2JR4/3142
Confirmed:
On Provantage, you can grab it for under $50. Everywhere else is around $70.
https://www.provantage.com/startech-pexusb311ac3~7STR9584.htm
https://www.startech.com/en-us/where-to-buy/PEXUSB311AC3
If you need more USB-C ports, make sure it's running the ASM3142:
https://www.startech.com/en-us/search?search_term=3142
JCAT uses the same chipset
https://jcat.eu/featured/usb-card-xe/
If your graphics card takes up two PCI-E slots and space is low, you can can a PCI-E extender:
https://www.amazon.com/ADT-Link-90Degree-Extension-R11SL-TL-Extender/dp/B07TBLB3L1/ref=sr_1_6?crid=AB57E30FS2XE&keywords=pci-e+extension+cable&qid=1666148599&qu=eyJxc2MiOiI0Ljc2IiwicXNhIjoiNC4zMCIsInFzcCI6IjQuMDMifQ==&sprefix=pci-e+,aps,164&sr=8-6&th=1
For optimal performance, use a USB optical cable. It's great for stability and Zoom.
I combine it with low latency realtime operating system running Steam, so I game completely in low latency heaven and run the operating system and Steam Games completely in RAM. Since Chord DACs have a bit of lag this compensates by not adding unnecessary fluff.
Would you run your Graphics Card off a Motherboard's USB port? Why suffocate your DAC? Give it proper bandwidth, stability and isolation with direct a direct bus to the CPU via PCI-E. Give it the same respect as a Graphics Card. You lower the noise floor too even without external power since you avoid the clutter of normal internal data workings.
MarkParity
Probably correct, but does the latest Poly F/W not possibly implement desktop mode? I will check again but after an overnight charge I thought I saw both Mojo 2 and Poly had a purple power status light.I don’t think it does. I mean the mojo 2 might go to desktop mode but the poly will not. Will be like you’ve left it constantly connected to power
MarkParity
Denon AH-D9200, that's the one I have my eye on as an option.STELLIA!!!
Nice Njoy!!The new boy just arrived!
AussieMick
People who love their Denon LOVE their Denon. Great choice!Denon AH-D9200, that's the one I have my eye on as an option.
My suggestions would be for you to do something about your wife. She should respect whatever hobby you are in and not treat you, and your gears as nuisance. You should not even let anybody treat you that way!Hello my friends, i have to share this with you.
- Divorce
Thank you, sirs
Are you a child?, if I was in a room and sat next to someone wearing leaky Sundara’s being played loud with an audible “tsk…tsk“ I’d be bloody annoyed as well.
