Chord will really need to knock it out of the park with "Hugo 3" to continue justifying the significant premium over Mojo 2...Fully agree with your comparison, yet the Mojo OG sounds really great with vocals and compared to other DACs at the price (used og) it still retains that natural quality of the Chord DACs. It has its own magic for me.
For example the Sony IER-Z1R has a quieter/recessed midrange and the Mojo OG really helps to bring vocals more forward and tame the bass and treble.
But no question, the M2 is overall the better DAC, much closer to Hugo 2.
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
ChrisGB
I find it odd that many reckon the Mojo 2 to be comparable to the Hugo 2. They exist in very different parts of the market and there is, in my experience, very clear space between them. Hugo 2 is a fair way up the diminishing returns ladder, but it is a few rungs up. Hugo 3 would very likely make a decent sized hole in my wallet.Chord will really need to knock it out of the park with "Hugo 3" to continue justifying the significant premium over Mojo 2...
Hi,Just got my new mojo 2. Without connecting USB, just plug in my earphone and turn mojo2 on and off. I can hear clearly a tiny noise appear when mojo2 is on and such noise is constant when I play music also. Is that normal for mojo 2 as a DAC to have noticeable noise output when there is no music signal?
Chord reply me that for sensitive earphone it is normal, and I just need some attenuation on the line.
I was using the micro iDSD black label before, that one did not have any noise noticeable. I am happy with mojo2, just interested to learn if you guys also notice some noise.
Thanks!
Thanks for the useful discussion these days, especially for comments from CaptainFantastic and Tiax. I think I now reach a conclusion.
I now have two Mojo2 at hand and they are both new. The hissing I have noticed does present at both unit similarly. It is a universal hissing picked up from my shure 535 IEM since after mojo2 boots, it is not loud but noticeable, seems like not influence my music, but definitely there. Such hissing does not relate to volume, connection of USB, etc. The hissing can be easily fixed by attenuation (ex ifi iEMatch).
My conclusion is the hissing is normal for mojo2 and my IEM combination. Otherwise it is hard to believe both new mojo2 has similar defective hissing plus their SN is far away from each other. I will keep the one and return another (simply choose the one with less hissing), with Amazon in US, it is super easy to return.
It seems like Tiax and CaptainFantasitc may have different issue, since their hissing is more like a defective unit and easily proved.
surfgeorge
Member of the Trade: 3D Printed Accessory Designer
I am sure they will, but my guess is that it will take a good while until we get to see an update.Chord will really need to knock it out of the park with "Hugo 3" to continue justifying the significant premium over Mojo 2...
Rob Watts has made a point of stating that he only makes updates that are significant and I take that to mean that Hugo 3 will be much more than just a Hugo 2 + EQ. Going by past experience it will be worth the wait and worth the upgrade...
Until then the Hugo 2 is a significant step up from the Mojo 2 and I am enjoying both of them
I wonder if a 2025 (assuming) Hugo 3 will still use Micro USB !!
Andrewteee
Well, the EU will require all devices to use USB C as the standard connection, though I'm not sure how that would impact devices like the Chord DACs.
I'm sure when streaming protocols develop a new poly will come along with Mojo 3
That's only for charging points..Well, the EU will require all devices to use USB C as the standard connection, though I'm not sure how that would impact devices like the Chord DACs.
They simply include an adaptor in the package, hey Presto , it becomes legal.
iPhones! they are in trouble.
Andrewteee
I heard a rumor (only a rumor!) that the iPhone 15 will be only wireless charging; no connector at all. That's pretty radical move because it would cut off all connection options, not just charging.That's only for charging points..
Apple stews in a world of their own, compatibility means zip to them. So sounds about right.I heard a rumor (only a rumor!) that the iPhone 15 will be only wireless charging; no connector at all. That's pretty radical move because it would cut off all connection options, not just charging.
I wouldn't be surprised if the wireless charging and future Bluetooth connections be only apple devices compatible.
Beauty of it is, that my daughters , would keep on buying apple regardless.
Why should apple change?
AussieMick
Maybe, if there is even an update and not a brand hew product, the “Hugo 3” will get a USB C input like the Mojo2? It’ll need to keep the Micro to attach the 2Go.I wonder if a 2025 (assuming) Hugo 3 will still use Micro USB !!
ChrisGB
That'll do wonders for the environment, given the losses in wireless charging. I wouldn't put anything past them though.I heard a rumor (only a rumor!) that the iPhone 15 will be only wireless charging; no connector at all. That's pretty radical move because it would cut off all connection options, not just charging.
Apple did embrace (possibly more correctly endured) using USB-C on most of the iPads so perhaps they will finally come around.
My iPad mini 6 with USB-C works flawlessly with data to USB DACs and power and data to an ifI Go Bar.
RumiKeys
Proud mojo 2 + poly user! Sound and portability king!
Guy Fawkes
Is it possible to stream music from the device (Android) to the Poly using the UPnp Renderer function of UAPP?
Total: 44 (members: 8, guests: 36)
