@dsrk is correct about Mojo2 fast charging.Yes, Mojo 2 supports fast charging. But for prolonged battery life, it is recommended to use slow charging whenever feasible.
However, beware that what Chord refers to as Fast Charging is not the same as what phone manufacturers mean by fast charging.
For a phone, fast charging means, in conjunction with an appropriate Fast-Charger that is smart, and has multiple output voltages, the phone can Ask the fast-charger to switch its voltage to 9V or more, to engage fast charging on the phone.
In Chord's case it is not so! Chord requires 5V all the time, 9V would damage it - However chargers can have 1A or 2A or more output. Chord devices try to pull 2A from the charger in order to go to fast-charge mode, if the charger can not handle it, i.e. the 5V rail drops voltage, then Chord devices switch to standard charge current of 1A.
Bottom line, one needs a genuine 2A or more standard charger for Chord, and not what is typically referred to as a Fast-charger.
