chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
Works, but not optimal is how I would describe the paring. It's a portal solution so gotta keep your expectations in check.Good evening
Has anyone used the Mojo 2 with the lcd 3? If so, could you share the DSP settings that equate to the recommended Audeze settings.
I am using an amp, is there enough juice to drive the Audeze?
If you are using a separate amp, then mojo 2 has no problem putting out a good clean signal to the amp. You will need a good front end to get the best out of mojo 2.
