dsrk
Mojo 2 drives LCD2C well enough but with A30 Pro or EF400 there is effortlessness, dynamics and smoothness. For a portable source Mojo 2 is not bad at all.Hi
I am using a topping A30 Pro connected to mojo 2 via 3.5mm to analogue.
The question was also whether the mojo 2 would drive them on its own.
I was also wondering whether a more expensive amp would make any difference; some recommended the Bryson bha 1
A30 Pro is good enough, it powers my HD6XX and LCD2C with ease. You can hardly find any difference between A30 Pro and BHA-1 if your source is Mojo 2.
Mojo 2 is an excellent device but if you are investing that much on an AMP, you can hear improvements with much better source like Hugo 2 or any other DAC with balanced output.
If you are not going to upgrade your source, then I would stick with Mojo 2 and A30 Pro.
