No. It is just a trickIs that "truly" balanced, then?
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
keithmarsh
Nope, nothing to do with anything balanced. Just a single ended adapter for 4.4 cables. Most of my good quality cabled are 4.4 so this is a good solution for me!
chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
So it’s just a straight up balance to se adapter. I guess the shape is for looks and structural stuff.
keithmarsh
Yep!
Not a trick - it is a converter so you can plug 4.4mm jack into Mojo.No. It is just a trick
It is a veeery expensive converter, but not a trick.
Does the same job as this:
https://www.amazon.co.uk/DD-Headphone-Converter-Connector-Amplifier-Silver/dp/B088WVMCTD
My Mojo 2 is auto shutting off after a while if no input is detected. The Mojo 2 battery is fully charged. Is this happening to anyone else?
keithmarsh
Yeah, I have the DDHifi ones but once you add the 4.4 jack it's quite a big lump sticking out of a small 3.5 socket. Even though the PW Audio one is pretty big (and expensive) it's actually a lot nicer in your pocket as the 4.4 jacks sits flush.Not a trick - it is a converter so you can plug 4.4mm jack into Mojo.
This whole hobby is based around expensive things we don't really need
Maybe to you, I am only after sound quality and convenience, in that order.This whole hobby is based around expensive things we don't really need
I would carry a Hugo2, USB cable and big headphones if I have to, not on the train or bus (too old for those).
keithmarsh
Really???Maybe to you, I am only after sound quality and convenience, in that order.
Do I need to clarify that was a joke. Jesus. Now I remember why I stopped going on head-fi.
Good luck on your very serious audio journey. I'm off to the real world!
No I got you, just forgot to put a smiley face after.Really???
Do I have to clarify that I was being humorous too??
keithmarsh
Oh, so sorry dude - my bad! It's been a long day!!!No I got you, just forgot to put a smiley face after.
jinx20001
- Jul 4, 2007
that does not sound normal to me, never had it in the time ive used it but i admittedly use it mostly desktop mode. i know the mojo does have a thermal cut off switch so if it gets too hot it will save itself by shutting off and it should be left 10 minutes before switching back on, however that is the original mojo and the mojo 2 is significantly more efficient with heat output far less (although i will say mine does still get hot to the touch even in desktop mode where battery is out of the equation).
i am slightly worried about how hot it gets, not had an original but with how warm/hot the mojo 2 gets i cant imagine how bad the original was, but we must keep in mind its an amp, they get warm by nature of what they are.
is yours hot when it shuts down?
Yes of courseNot a trick - it is a converter so you can plug 4.4mm jack into Mojo.
Pier Paolo
- May 29, 2012
Mojo 1 and 2 switch off automatically after 10 minutes, if no input.
billymisfits
does this give you more power/volume?Absolutely love this 4.4 adapter. So sturdy and solid. Feel much more comfortable with having it in my pocket and not having the headphone sockets have strain put on them. I find that it doesn’t colour the sound either like some adapter do!
Total: 31 (members: 11, guests: 20)
