Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Jan 27, 2022 at 4:27 PM Post #1,051 of 10,458
Jan 27, 2022 at 4:33 PM Post #1,052 of 10,458
I got to see some bits meant for the press- quite excited about this release. Definitely not what I expected!
Jan 27, 2022 at 4:47 PM Post #1,053 of 10,458
Press "M" when you need a little bit
Jan 27, 2022 at 5:44 PM Post #1,054 of 10,458
Jan 27, 2022 at 6:03 PM Post #1,055 of 10,458
I would say 'M' for MODE
I would agree although it would be really cool to be a mini mscaler. But, mode would actually have more utility. We will find out next week.
Jan 27, 2022 at 6:26 PM Post #1,056 of 10,458
I thought it might be an input selector since Mojo 2 supposedly has four inputs. Maybe that was too many for default input selection. However I doubt they would use M like meaning mode, for input.
Even something like as folk have said, more taps for desktop use, why use M. Maybe mode would suit that though, as desktop mode - more taps, vs battery mode.
It would be really quite cool to be able to choose how many taps to use.
M is for mode. Mobile or desktop
Jan 27, 2022 at 6:35 PM Post #1,057 of 10,458
449£
Jan 27, 2022 at 6:41 PM Post #1,058 of 10,458
Jan 27, 2022 at 6:46 PM Post #1,059 of 10,458
From avcat.jp
Uncategorized
Chord Electronics
Mojo2
Black Finish Only
Price: £ 449 (UK)
About 7 years after Chord Electronics created the portable headphone / DAC amplifier "Mojo", the new "Mojo 2" is released.
UHD DSP
・ Advanced DSP allows integrated tone adjustment over all frequency bands
・ UHD DSP technology operates at 705 / 768KHz
・ Uses 104bit and extended internal noise modulation
・ UHD DSP provides bass and medium The entire frequency band can be adjusted in 18 steps for each frequency band of bass, bass, and treble.
-The volume adjustment range has also been improved from + 18dB to -108dB. It has two types of operating ranges, low volume and high volume.
・ It is equipped with a new cross-feed mode with 4 settings controlled by DSP, realizing a space effect for listening like a headphone speaker.
・ Introduced a menu system
Equipped with a mute function, 4-step customization function, travel button lock function, tone control function, etc.
・ Digital input
USB-C input has been newly installed to increase the number to 4 systems, enabling more flexible support.
USB-C, optical, coaxial (including dual data for M scaler), and Micro USB installed.
3.5mm mini jack headphone output There are two systems, and up to two people can listen to music at the same time.
-Charging system
New FPGA-based charging system greatly improves battery management
This technology significantly improves charging speed, reduces power loss by 75%, and enables more efficient charging.
Increased capacity by 9%, improved performance and improved battery life to over 8 hours
-The "Intelligent Desktop Mode" technology has also been improved to support batteryless operation by redesigning the battery isolation and power supply.
・ Improved WTA (Watts Transient Aligned) filter to achieve 40,960 taps (technical indicator of interference filter complexity) using 40 DSP cores.
・ Improved noise modulator improves depth and detail, and improved 4e pulse array DAC reduces distortion and out-of-band noise.
・ Abolishes coupling capacitors to achieve higher neutrality.
・ Mojo 2 is designed and manufactured in the UK. Uses a high-quality aluminum housing with a black finish that has been sandblasted.
Mojo 2 is fully compatible with Poly Streamer / Server, allowing you to store and play up to 2TB of solid libraries when using high resolution streaming and microSD card slots.
Jan 27, 2022 at 6:54 PM Post #1,060 of 10,458
no Bluetooth 😟
Jan 27, 2022 at 6:56 PM Post #1,061 of 10,458
Jan 27, 2022 at 7:00 PM Post #1,062 of 10,458
From avcat.jp
Uncategorized
Chord Electronics
Mojo2
Black Finish Only
Price: £ 449 (UK)
UHD DSP
・ Digital input
-Charging system
Well, we got USB-C. That's a big one. Also have Desktop mode which is big.
40000 vs 27000 taps for Mojo OG. That's an improvement.
I guess "M" means desktop mode.
This is slightly better than Mojo OG.
Jan 27, 2022 at 7:02 PM Post #1,063 of 10,458
No need to double check any other equipment, they had me at 75% battery improvement.
Coax still working so my dear xduoo 05bl still working. Ladies and gentlemen (mainly gentlemen in this forum TBH) we got mojo2, and i cant be happier with it. It SOUNDS promising.
Jan 27, 2022 at 7:05 PM Post #1,064 of 10,458
So, basically a Hugo 1.5 without bluetooth? Can't wait for some listening impressions!
Jan 27, 2022 at 7:06 PM Post #1,065 of 10,458
