From avcat.jp
Uncategorized
Chord Electronics
Mojo2
Black Finish Only
Price: £ 449 (UK)
About 7 years after Chord Electronics created the portable headphone / DAC amplifier "Mojo", the new "Mojo 2" is released.
UHD DSP
・ Advanced DSP allows integrated tone adjustment over all frequency bands
・ UHD DSP technology operates at 705 / 768KHz
・ Uses 104bit and extended internal noise modulation
・ UHD DSP provides bass and medium The entire frequency band can be adjusted in 18 steps for each frequency band of bass, bass, and treble.
-The volume adjustment range has also been improved from + 18dB to -108dB. It has two types of operating ranges, low volume and high volume.
・ It is equipped with a new cross-feed mode with 4 settings controlled by DSP, realizing a space effect for listening like a headphone speaker.
・ Introduced a menu system
Equipped with a mute function, 4-step customization function, travel button lock function, tone control function, etc.
・ Digital input
USB-C input has been newly installed to increase the number to 4 systems, enabling more flexible support.
USB-C, optical, coaxial (including dual data for M scaler), and Micro USB installed.
3.5mm mini jack headphone output There are two systems, and up to two people can listen to music at the same time.
-Charging system
New FPGA-based charging system greatly improves battery management
This technology significantly improves charging speed, reduces power loss by 75%, and enables more efficient charging.
Increased capacity by 9%, improved performance and improved battery life to over 8 hours
-The "Intelligent Desktop Mode" technology has also been improved to support batteryless operation by redesigning the battery isolation and power supply.
・ Improved WTA (Watts Transient Aligned) filter to achieve 40,960 taps (technical indicator of interference filter complexity) using 40 DSP cores.
・ Improved noise modulator improves depth and detail, and improved 4e pulse array DAC reduces distortion and out-of-band noise.
・ Abolishes coupling capacitors to achieve higher neutrality.
・ Mojo 2 is designed and manufactured in the UK. Uses a high-quality aluminum housing with a black finish that has been sandblasted.
Mojo 2 is fully compatible with Poly Streamer / Server, allowing you to store and play up to 2TB of solid libraries when using high resolution streaming and microSD card slots.
