lmfboy01
- Apr 26, 2007
so quick question is the mojo better than onkyo balance out?
I own both the AK100 and AK120 and fill both slots with 128GB cards. Total songs in the device is around 8500. No lag or delay at all when browsing or playing EXCEPT when playing DSD files. Then browsing becomes slightly laggy and delayed. If you pause the track, everything is back to being smooth again.
Best sound I heard so far is Chord Mojo with Final Audio Piano Forte VIII, the synergy is just perfect. Sounds even better than JH Angie, Sennheiser IE800 and other of my full sized headphones (Grado PS500, GS1000, MDR-Z7).
I have a 100mk2 on order and a cable meant for stacking port over port to the mojo, but the 100mk2 is now on backorder (hopefully comes in). If I have to get a 120 (non- II), I would like to know if my cable would work with the 120 should the need arise.
Would you mind seeing if the mini output ports on the 100 vs 120 line up please?
Very much appreciated!
Hi San Man,
The 100 and 120 are identical from the top down. Only difference is the length (height), with the 120 only slight taller. Other than that, all other dimensions are exactly the same, width, thickness, ports and button placements, screen size.
Quick question: They don't look like they have silicone tips so how do they seal or does it not need a very tight seal?
Been reading up on these, no tips, no seal
Yep. Due to this they are not really "on the go" IEMs as they risk falling out if you move too much. Also IMHO they're a bit of a unique/acquired taste, and weren't my cup of tea, but FAD does appear to sell a lot of them. Cheers
I think we should rename this thread in IEM suggestions for mojo...
