davidmolliere
This is baffling and I'm afraid I don't have the answer, hopefully after a full charge things might have righted itself. If you haven't done so yet maybe an idea to post this in the Chord Mojo issue solutions thread. as well, just to correlate this and other problems experienced by all users.
I try to avoid double posting, but I will eventually if there is no answer.
I don't think charge will fix it, it wouldn't make sense that's wishful thinking on my part
Are both balls the same colour?
Is everything plugged in securely?
Both balls are the same color and everything is plugged securely, I have done and re-done it, with 2 different cables that I know worked before.
I tried setting to line out, turning off, and start it again but same result
