My Mojo has landed - now to figure out which IEM/CIEM to try first....
V6-Stage + Toxic Silver Widow?
Your Noble K10's, oh wait, sorry that was mean.
Really? Didn't get it to work before. Will try again and hope it does work. Thanks!
can we move beyond the "____" jokes.![]()
From 4 days (and 32 pages) ago:
Well if the dealers had enough stock I could be comparing the Mojo right now to the Yggy , Gumby , 2Qute , ifi idsd and 2qute which I happen to have !
So lighten up .
Agreed.
Can we?
Please...?
Agreed.
Can we?
Please...?
This is very exciting!
Do you feel having both dac 19 and Mojo is redundant? Which would you keep if you had one to pick.
I can sort of see (well, hear!) the point people are making about the amp section, I will confess openly that my Pure II+ has way more headroom, power and clarity compared to the onboard amp, then again, should be considered that the amp on its own costs the same, if not slightly more than the mojo (depending on your market) so I would be upset if it wasn't better!
That being said, you have arguably a world class DAC and a pretty damned decent amp enclosed in a really small package for what is ultimately a very modest price...
You shouldn't be disappointed with it out of the box, but always consider that it has a line out mode for a reason, and if you have a good enough amp that still fits in your pocket (thankfully the Vorzuge fits in a very similar footprint!) then why not, best of both worlds![]()
The HD650 is 103dB 1mW 300 ohms. With Mojo's 5.3 V RMS into 300 ohms, that works out at 122 dB SPL.
Need ear defenders too!
Rob
Ok...at the meet in CT and I bought the to go cable and I still can not get the mojo to work with my SAMSUNG NOTE 4?? HELP!!!
So strange that it finally worked once you put some music on your internal storage. Has anyone else had the issue where it refuses to play music on a SD card and only will play off internal storage?
That is the way I have been using my CDM since I have it. In addition you get much more power out. You can probably increase further the soundstage by using the USB input of the CDM, but for me Hugo/Mojo SE out to CDM Balanced out to an HE1K is the best combination for DSD (CDM DAC does not work well in DSD with Mac Audirvana). I must say that the Wolfson DAC in the CDM is really good and in PCM it is really hard to differentiate it with the Hugo knowing that in increases the soundstage further (It is balanced out from the DAC). I do not have the Mojo yet, but I am looking forward to compare how the combination will play on the warm side. Too bad Chord dismissed balanced out on their portable gear. I talked to Rob Watt about it but he did not convinced me in saying that SE was as good as balanced.
You are 100% correct that the CDM can play balanced off the SE input of the Mojo. Why the heck didn't that work the first time I tried it?!?
Anyway, continue to recommend that pairing - AK100->Mojo->CDM.
For those that say the CDM tube-amp only adds "noise" or makes it less "real" - if the sound I'm hearing is wrong, then I don't want to be right!
Cheers
Cheers
I am considering an AK100 as they get pretty cheap, that would use with optical output to mojo. What would be the limitations of this setup in term of playback capabilities (DSD, 24/192KHzPCM and so on?) I guess everything gets out in PCM including DSD but is it an equivalent of DSD over PCM we have in Audirvana?
Also what is the biggest micro SD that can be slotted in? as I saw that 200GB are available now
Thanks
