Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Mar 19, 2022 at 3:42 PM Post #42,346 of 42,765
Hi all, I would like to share how I upgrade the Chord Mojo to have Bluetooth Receiver and USB C Connector.
As suggested by the previous post, I use XDuoo 05BL Pro and create a 3D printed casing for the PCB and Batteries. The result is something similar to Chord Poly, but smaller. After the upgrade:
- Bluetooth receiver up to LDAC, auto quality is very similar with direct DAC
- Media control button
- USB C Charging port for both XDuoo and Mojo
- USB C DAC port for Mojo
The CAD file for the casing and the step by step is also being shared under this blogpost link. Please do give your comment or suggestion for this project.
Excellent .
I did something similar, though not this elaborate .
Just get a poly sleeve and paint it matt black for looks.
Well done.
Why are there two batteries?
Mar 19, 2022 at 7:27 PM Post #42,347 of 42,765
Excellent .
Well done.
There are one battery for the Xduoo 05BL Pro and another battery for Chord Mojo. I use the original USB C charging port on Xduoo 05BL Pro to charge both devices, the 5V is tapped from its PCB and connected to the micro USB cable that connects to the Mojo charging port.
This way connecting a charger to the Xduoo 05BL Pro port charges both devices.
Mar 19, 2022 at 8:13 PM Post #42,348 of 42,765
OK I got that about the plugs and sockets and charging bit.
What I don't get is that Mojo has a battery builtin, why did you add another?
To give it a cleaner power?
To give it a longer play time?
Mar 19, 2022 at 10:42 PM Post #42,349 of 42,765
No, I did not add battery to the mojo, I use its original internal battery for it, the battery you see attached to the PCB is the original battery from XDuoo 05BL Pro.
On the power side the only mod is to connect the 5V from the XDuoo to the mojo charging port. Take note that this 5V supply is only active when you charge the XDuoo via its USB C port, this way it charge both device at once.
Mar 21, 2022 at 2:00 PM Post #42,350 of 42,765
Incredible. I'd buy this over the Poly any day of the week.
Mar 21, 2022 at 5:51 PM Post #42,351 of 42,765
I thought this was a battery too!
I was thinking of putting the same BT module into this:
This is not Poly! this is from Mojo cable pack, which is basically the shell from a Poly as a passive adaptor to connect USB and other stuff to Mojo.
There is plenty of empty room inside for the module, and microUSB sockets and plugs (straight wired) and a simple plastic line (similar to a thick fishing line) that acts as a sort of optic fibre to relay mojo's battery-life LED to the outside.
It would have almost been a Poly knock-off! no WiFi, but better BT connection.
Mar 22, 2022 at 4:04 AM Post #42,354 of 42,765
the "UGREEN" is actually USB micro to USB C converter to convert the DAC port to USB-C.
Ya, my initial planning is to get the Mojo cable pack, but it's a bit hard to get here in Malaysia, so I go with 3D print.
Mar 22, 2022 at 8:45 AM Post #42,356 of 42,765
Mar 22, 2022 at 10:43 AM Post #42,357 of 42,765
Mar 22, 2022 at 12:46 PM Post #42,358 of 42,765
Bravo. Talk about some un disruptive modding!
