Amberlamps
Formerly known as Phuca
- Jan 22, 2017
I want one, but I won’t be amongst the first to buy one, I’m just going by their past releases. However I hope this release goes well for them.
It’s still there when battery gets full. I notice it even when charging MojoPoly together.Some of you might remember this: remember that first day you replaced your Mojo battery after it would die after a few minutes or a few seconds or wouldn't even turn on?
How awesome was that day?
On another note: has anybody noticed white/hiss noise after changing the battery while the usb charge cable is in the socket? It has been soo long that I don't remember whether there wasn't or was white noise?
The Anker power bank makes sense. So you use the Anker power bank to charge after the Mojo battery runs out?I use an Anker power bank and it even gets less warm than from my wall adapter; It is totally silent too. I really recommend using a power bank.
You could also get a linear power supply but I just cannot justify the price (better ones go for $150+ usd). And in most cases, the best linear power supplies have capacitors to act "like a power bank" and provide constant linear power, that's why most of them have power after disconnection. The power bank is just cheap enough and works really well.
I think Anker used to get many recommendations in the earlier years of this thread.The Anker power bank makes sense. So you use the Anker power bank to charge after the Mojo battery runs out?
I prefer vinyl over all digital sources: the linear power supply price problem pops up every time I look at a phono stage. Makes me think about trying a power bank for my phono stage. thanks!
I closed my ears to this forum in the early days of the Mojo. I didn't want to believe a battery problem existed.I think Anker used to get many recommendations in the earlier years of this thread.
I assume if you search this thread using a keyword like Anker, you should find a few posts.I tried to closed my ears to this forum in the early days of the Mojo. I didn't want to believe a battery problem existed.
Yes, I try not to use it while mojo is on, mainly because it produces more heat, and in the end even if the battery is rated to work on hot temperatures the least heat you put through the battery the better.The Anker power bank makes sense. So you use the Anker power bank to charge after the Mojo battery runs out?
Plenty of diagrams on pinterest or diyaudioЗдравствуйте!
Скажите есть ли принципиальная схема усилителя мощности?
Может быть есть статья о том, как устроен усилитель для наушников?
Hello!
Tell me is there a schematic diagram of a power amplifier?
Maybe there is an article about how a headphone amplifier works?
