Pocomoto,
You can use the Mojo without a battery as desktop DAC, just be aware that the charging circuit will remain ON if the Mojo stays connected to the 5V USB source, even after you power the Mojo OFF.
I realized this the other day when i hadn't used it for a couple days and noticed it was slightly warm to the touch. Now i just disconnect the USB cable when not in use.
Edit: As a desktop DAC you are essentially charging & playing, therefore the unit gets very hot but at least the battery is no longer getting cooked inside.
There is no memory issue with LiPo's.
Just fully charge it as standard.
If you continually let it drain fully, you shorten the life.
When it gets to yellow, or just red, charge it up again.
Since Ali's battery is not from CHORD, I suggest you do not charge it while you use it, as it generates good amount of heat, which I am uncertain how it would affect the unofficial battery.
Others have been using Mojo, without a battery as desktop DAC.
It evidently does not cause any damage.
I, however, have advised against it theoretically, but others swear by it!
Thanks Kentajalli, That is just what I wanted to know. Strange as I thought kept mine on full charge. Before I got it I would borrow my son's Mojo, and his is still going strong on same battery maybe 5 years now.. Maybe it runs down when not in use, there were periods I left it in the box while I played with other stuff.
