imattersuk
- May 11, 2014
http://www.custom-cable.co.uk/vertere-micro-usb-to-usb-b-usb-otg-on-the-go-cable.html
Micro to Micro option
£100 lol
actually as someone who does development, the idea of cables affecting sound significantly is alittle weird since the only reason the sound will change is unless a lot of bits are lost or corrupted. Audio is technically a stream so I'm guessing there's no garuntee of data integrity but seriously most cables will probably lose very little bits. When have we last use a cable that always corrupts the file when transferring data. A perfect cable will have no data lost but that's still subjected to the connector and device hmm. I'm sure a perfect cable and cheap one does have a difference but probably in very minute details.
But hey we are in this hobby, every little bit to perfection counts as long as you can afford it and there's a difference to you.
Does anyone know if the headphone socket on the new Macbook MJY42B/A also outputs a digital signal like the Macbook Pro ? In this case Google is not my friend, can't find a definitive answer anywhere. Might have to make a trip to the Applestore armed with a Mojo.
I'm sure you've tried different IEM cables. Did you not notice more brightness (or more mids, for example) with different cables?
I tried three or four different cables with my Earsonics Velvets - just to see if it made a difference. I found one that did and then found an even better one that sounded better on day one and still sounds better four months later (I've A/B'd with the stock cable to make sure!). In fact I've walked away from buying new high end IEMs because they didn't sound as good as the Velvets with the cable upgrade (YMMV of course, but I'm sure the same would apply with Nobles etc etc).
The one that surprised me the most was swapping my usual Apple CCK + mini USB to USB interconnects (one from ALO and one from Moon Audio) for an all-in-one Lavricables interconnect (which does away with the need for the Apple CCK). The SQ difference was noticeable, and underlined my belief that the Apple CCK is the weak link, even if you have a TOTL interconnect from the CCK to the DAC/amp or amp. It cleaned up the signal a lot, and the brightness of the silver interconnect was much better than the Apple CCK + whatever.
Look on the manufacturers website.![]()
Yeah analog has way more variable so a proper cable is more important there. Digital has a lot more tolerance to fault by design. However a good cable is still a good cable, its possible to reduce chance of corruption and missing bits. So the gain in having a better cable for digital is probably still there just smaller.
I think I would probably pay up to £20 for a well built OTG cable
Is that the £690 one on their ebay store ? Please tell me in all seriousness it's a typo and should be £69.
Haha if its the Lavricables one then it's a typo! Definitely without the extra zero!
I have no affiliation by the way. In fact, I had a problem with one but I think it was my iPhone rather than the cable. And the SQ when it worked my really good.
