Not hugo 3.. but they have some plan involving hugo 2..i dont know what it is
what i can confirm is no mojo 2 anywhere soon .. no plan .. wonder how long will it take to research and manufact LOL
Rob has occasionally posted that the Mojo is as perfect as he could get in that small
mobile case size.
https://www.head-fi.org/threads/chord-mojo-dac-amp-☆★►faq-in-3rd-post-◄★☆.784602/page-2367#post-14076353
Thermal issues were a big constraint - if you want more processing/taps, then the case/battery size needs to increase, unless the next generation of chips becomes available at an economic price of Rob/Chord.
It is true that posters do suggest other improvements such as screen, incorporate streamer functionality, updated battery charging, improved signalling to Poly about battery status, different usb/headphone sockets, but many of those would require an increase to case size.
It is not surprising that there are no hints from Rob about a Mojo2 being under development.
In contrast, there are often posts asking for a desktop version of the Mojo - so removed from the constraints of mobile use (eg case size, need for battery).
Then you are starting with a half blank sheet of paper:
- retain everything good from the Mojo
- incorporate improvements relating to streaming, sockets etc (maybe the case would need to be slightly increased in size)
- replace battery by supercapacitors (so can be left connected to power 24/7 permanently)
To me, such a design is more interesting than mere tweaks to Mojo1, and I think would find many buyers. I suspect that marketing would respond, that the device was no longer mobile, so could not be called Mojo2, but maybe babyTT or something similar.
Again there have been no hints about such a babyTT, so the above are just christmas musings.
I think there is a post somewhere, that the Mojo took one year for research>design>testing>production, so that is probably a good baseline for many of the new products. A simple tweak like just change a usb socket, would be much quicker.
