stoobot
Out of curiosity, anyone who uses the mojo with a Mk 1 AK70... how notable is the difference between the direct out on the AK70 and going via the mojo? Cheers!
Cool thanks, let me see if I can reach out to them. I was within warranty but trying to get Chord to do warranty work is impossible.If you purchased from a hifi retailer they supply batteries from chord for around £40 if I remember rightly
This is clear, however electrically it is advantageous to have the port directly soldered. Everything is a compromise in the end, I'm happy with the implementation but then I only transport the Mojo inside a waterproof Peli case.
Dude, would you mind awfully to make a small test with the S5? One would be to check the interference with a sim card in and check for interference (only if you're fine with sliding in a SIM card into it) and the second one would be to check if a DSD128 file plays correctly. These are the two things I struggle with the S5 and some other people don't seem to have issues with (at least not with other phones).
Ps. 6.0.1 should be the latest Marshmallow version for the S5.
The Mojo case is aluminium so it is well shielded. The rfi is entering via the usb cable. Are you still using the samsung? When i was using the samsung galaxy note 3, all it took was to add one ferrite choke to the usb cable, to remove the rfi.Hi again,
Good news DSD 128 is playing fine, UAPP / Mojo is showing DSD colour, and it sounds stunning out of my cans!
Bad news, cellular interference is there, enough to annoy and ruin ones mojo, pun, or in this case not at all funny reference, intended!
Im actually quite annoyed by this, even though it may not effect me. Surely a very large percentage of Mojo owners will be connecting Mojo to phone?
Inexcusable cockup on Chords part, it should've been well shielded against those frequencies. I imagine there are many very fed up phone/Mojo owners?
I trigger the line out mode (take it down to 1.9v)
Why everybody does that (not staying on 3v)? And do you symply push down the volume x times to achieve that after you turn on the lineout mode?
old school. inputs used be at 2v and some systems can't handle more (or distort above it), but most amps can take it. still, 3v just feels hot so I click down 4x to 2v.
Hi,The Mojo case is aluminium so it is well shielded. The rfi is entering via the usb cable. Are you still using the samsung? When i was using the samsung galaxy note 3, all it took was to add one ferrite choke to the usb cable, to remove the rfi.
Hi again,
What would be a desktop version of the mojo? Any alternatives, don't want to use the mojo for desktop due to the batteries![]()
Hi,
I agree in part, i also considered that. The is more to shielding than just a case, thick aluminium or not.
It really should've been incorperated internally.
