turkayguner
Hey guys is there any working lightning to micro USB cable for iPhone v10.3.3?
There are a few posts stating that 10.3.3 works ok with the new CCK3 cable, but not everyone reports 100% success.Hey guys is there any working lightning to micro USB cable for iPhone v10.3.3?
I am not totally sure what CCK3 is but I bought a CCK cable from Apple last year and at the moment it works fine. What I was asking for was a short cable which is lightning connection on one end and micro usb on the other end. Issue with CCK cable is it doesn't look reliable when it is attached to another cable because the USB cable puts a lot of weight on the fragile lightning end and it also creates a lot of bulk which is against the purpose of MObile JOy. I bought the cable accessory pack. But this time the iPhone extension module forces me to remove the beautiful case which I also bought. What I do right now is carrying the pelican case came with my Shure SE846, stuffing Mojo, a bunch of cables and CCK and IEMs in it.There are a few posts stating that 10.3.3 works ok with the new CCK3 cable, but not everyone reports 100% success.
So things are looking more promising, but you may want to wait and see what feedback arrives when people have tried the iOS 11 beta.
Tonight I am listening to Keith Jarrett's The Koln Concert, a 96K digital download I purchased a few years ago. I'm using Foobar on Windows 10. Foobar reports a sampling frequency of 96K but the Mojo is red indicating 44K. Any thoughts why that is?
Are you using the Foobar wasapi component? If yes then check that you don't have resampling active.
I need a little troubleshooting.. my Mojo is 1 and a half years old, and I used it mostly as a desktop dac for my PC, plugged in almost all the time (shared the charger with my phone)
Atm i'm on a trip and I didn't used it the last 2 weeks and it seems that it's discharged.. I tried leaving it overnight turned off(with 2 different chargers and cables) but it still doesn't start, and the charging led doesn't light up when it's plugged in. It starts only if its plugged in and seems to work fine but it makes a t t t t t t t t sound at the start when the power light is going through the colors.
1. plugged in while switched off, only the lights flicker once, nothing happens, no charging led no matter how long I let it charge
2. connected to the laptop and charger, makes that sound at the start(v faint whine afterwards) works fine while plugged in but dies instantly if I remove the power
L.E. maybe worth mentioning: couple of times in the last months at home it switched off while listening to music with the battery depleted even if it was plugged in (resolved by removing and reinserting the charging cable)
FLAC is just a codec Free Lossless Audio Codec.Supervisor, indicators color is not the main issue. The main issue is that theres is a very slight or near no difference between mojo or no mojo when playing flac and 320mp3. Is your point is that theres no point of using mojo with flac and mp3, only with higher resolution files?
