x RELIC x
But balanced doesn't necessarily mean better... Just my two cents...
Did I say anything about better? I said differences.
It is a good question. I suspect you will here a bigger difference between different quality cables and connectors than you will hear between rca left right vs mini jack. I use the mini jack as a pre out to drive a power amp. It took me a while to find a cable/connectors that I was happy with, but now I am very pleased.
And that's why it is better than many DAPs out there which are worth multiple times of its price. Kudos to Rob Williams.
Did I say anything about better? I said differences.![]()
Just saying dude. Peace.
You mean Rob Watts.![]()
Yes, Rob Watts. I hope he makes a DAP so I don't have to buy the SP1000. Always prefer a one-brick solution when I am out and about, it makes me look stupid swiping the iPhone with the Mojo connected. At home and when I need some isolation with the IEMs, I always reach for the Mojo though. Simply put, it is indeed better than my AK380Cu in terms of sound quality despite it is many times cheaper.
Well you're preaching to the choir. Again, I never said balanced was better by default. Peace.
You got some pretty amazing gear in your signature file. How would you compare the Dave-Utopia setup with BHSE-SR009 (assuming Dave is the source)?
Back to the topic I think the Mojo compares favourably to many desktop DACs. The Mojo beats all Schitt DAC products for example in my opinion. I really hope they release a DAP.
Well, given the impending release of the Poly I doubt a DAP is on its way.
iPhone 7@junix Which Apple device are you using?
Just to get your opinion - would you say paying $1K more than the SP1000 for a second hand Dave, is a much better investment than buying the AK SP1000 itself? I am currently using Weiss DAC202 for desktop playback.
Depends what you mean by 'high quality'.By the way, probably someone has already asked, can someone recommend a high quality short cable from USB-C to micro USB so I can use my Samsung Galaxy S8+ with the mojo? Thanks.
Look at my answer, two replies above this yoursBy the way, probably someone has already asked, can someone recommend a high quality short cable from USB-C to micro USB so I can use my Samsung Galaxy S8+ with the mojo? Thanks.
