Dobrescu George
Reviewer: AudiophileHeaven
Every single component in the audio path subtracts from transparency. There is no question about that. 1+1=/=0.
You can not add two things and have less noise/distortion. It doesn't work that way. Also, the Mojo on its own measures much better than the O2 with less internal components in the signal path with an extremely simple analogue section. The O2 has more internal components in the signal path. The O2, by the laws of physics, is adding it's own flavour (no matter what the O2 fans say). It's just what's happening. The Mojo has it's own smoothness and the O2 has it's own brightness. If one likes the synergy of the two together, or on their own, that's fantastic but it isn't more transparent.
FWIW, I passed on purchasing the O2 (JDS Labs version) when I demoed it long ago because it had a grain and harshness to the sound and I found other amps to do much better than the O2 for my tastes. Again, I am glad if one finds the older conventional design of the O2 more preferable, but it simply isn't more transparent than the Mojo no matter what the marketing says.
As far as 'driver control' the Mojo and O2 (JDS Labs version) have about the same output power with the Mojo having the lower output impedance and better distortion measurements. Also, the Mojo has more Current output than the O2 (JDS Labs version). The headphone driver also doesn't care about what unused power it isn't being fed if using more powerful amplifiers. The headphone only sees what is sent to it for the volume one is listening at.
I respect what nwavguy has done with the O2, but I disagree with some of his assumptions about audibility. Good enough isn't always good enough. Of course, one more time, this doesn't account for personal preference. If the O2 is ones' preference then that's fantastic. We all like what we like and if the Mojo doesn't float your boat that's perfectly valid. I'm simply saying the O2 is not more transparent based on component count and measurements.
Well... Makes me wonder the following:
I'm using EQ to alter my musica, is it some kind of heresy using Mojo + EQ since using EQ would negate all the efforts of keeping the signal as clean as possible?
