- Feb 11, 2008
well looking at Dave, Dave got 3 things which are better
- Better noise shaper (350 DB) compared to 200 DB in Mojo, Hugo and TT
- More taps (168,000 vs 26,000 in Hugo and Mojo)
- 2nd order noise shaper analog stage.
Unless there is some magical FPGA that gives Dave Spartan 6 LX75 capability in the size and price of the Artix 7 (which isn't going to happen in 2017), I see 0 % chance of a Mojo update.
Actually, Chord does not publish or say how many taps are in the Mojo. I think because it's implemented in a different way than their other products.
Chord were reticent to discuss it, in the early months, after release, but eventually relented:
Regarding Mojos number of taps vs Hugo, they're allocated and run differently, but the end result is equivalent performance, and in fact, part of Mojos code is newer than that in Hugo, allowing the WTA filter to run at an eye-watering 768 kHz, if you had such files and a transport capable of feeding them to Mojo! (totally unnecessary, at this point in time, but the capability is there). The point is that Mojo is a very potent DAC and it would be incorrect to assume it is only has a fraction of Hugos capability.
Just to correct things - it is a 15T that is used on the Mojo.
That has 16,640 logic cells and 45 dsp cores. 44 cores are used in Mojo.
The overriding design decisions were about power consumption, so although more DSP cores are used than Hugo, that's to reduce power, as the DSP cores are run at a much lower clock speed. To give you another example of lower power, with Hugo when I needed a bigger multiplier I used one DSP core with FPGA fabric (logic cells) added to create the larger multiplier. With Mojo, to save power, I used multiple DSP cores and no fabric to create larger multipliers.
Only the WTA filter is different, the rest of the audio path has Hugo code.
Rob
26,000 taps is the closest to a definitive statement as I've read ... the same as I've seen specified for Hugo.
I'm sure it's called out earlier in the thread, just going from memory as I'm far too lazy to search for it!
Actually it's about twice as many as Hugo but run at half the speed giving approximately the same number crunching power in terms of DSP ..... We have mentioned this before, but didn't want to put much focus on it as this is a small only part of the over design of Rob's overall topology
it was always our intention to try to match the performance of Hugo To do this without using as much power as Hugo. Therefore Rob used more DSP cores but run differently to match the performance of Hugo but at far lower power demands. JF
