jmills8
Previously known as bmiamihk, jmills2
This sounds great with the Mojo and iems.
https://www.youtube.com/shared?ci=nqQJqfGerGA
Are you saying you are unwilling to allow Mojo time to charge without simultaneously listening to music?
The problem still exists even if you are not listening to music, as long as it's on.
what ever the numbers you choose, the mojo with headphones outside I loose bass and bass impact. Even eq the mojo not enough. No add an amp or amo to dap and bass imoact makes the headphone shake outdoors or inside. Mojo or hugo outside with headphone bass liss, with iems bass has very strong impact.BTW even with no boost theres inoact with the amps. And I EQ the mojo, I eq the bass wat up through music apps.jmills8
For other Head-fiers, I would like to add that Vorgzuge Duo & Arrow amplifiers:
- have Bass booster options.
Bass are amplified up to +15 dB
- have less output voltage & power vs Mojo.
Mojo maximum output voltage is around 15 Vp-p or 5.3 Vrms.
Therefore the enhanced bass preference you have has nothing to do with Output Power specifications.
Rgds.
I think for outdoor use, the selection of a iems with more bass is more practical than using a external amp to boost the bass.
I've noticed a consistent issue with my new Mojo in regards to playing DSD64/128 files. After the first song of an album plays through, the Mojo plays hiss on the second track. If I return the second song to the beginning, it plays fine. Then the same thing happens with the third song, and so on and so on.
This has happened with several of my DSD files. I know the issue is not with my AK240SS, since it plays a DSD album straight through.
I'm hoping for some comment from the Chord team as to what this anomaly might be ...
Still hoping a member of the Chord team can address this issue with DSD files ...
I'd like to add that not every one of my commercially bought DSD files has this irregularity, only some of them do.
Are all your files the same bitrate, or are you playing a sequence of tracks, each with different bitrates?
Yes, most of my DSD albums are DSD64, through and through.
Some play through perfectly. Some play the first track and then hiss. After skipping forward or back, the hiss goes away for good. Others have the hiss after every track. There is no intermittent behavior, happens the same way with each album.
When I use my AK240SS as a DAP and play these same albums, no issues. I suppose since the USB digital output for the 240SS is a new function from the last firmware update, it could be an issue with the DoP functionality.
Fortunately, I don't have this issue with the hi res FLAC albums I own, not the CD rips I did in ALAC, both of which represent 98% of my library on my 240SS.
I'm just curious as to whether this issue has come up for other users, hence, my reach out to Chord for some insight.
There have been issues when users play a sequence of files that change bitrates, and the Mojo is designed to pause for half a second until it has identified the new bitrate.
Your problem does sound like Mojo is playing 'hiss' because it does not know what the bitrate of the new file is - but it is not clear if that is because the files are output from the DAP normally but change bitrate (but you give the impression that the bitrate is not changeing), or the alternative that some software setting is stopping the next track being output from the DAP, and so the Mojo is just trying to decode/play 'no input' which sounds like hiss.
So I don't have a definate answer, but maybe something is stopping your DAP sending the output file to the Mojo - maybe the 'handshake' is being lost, and so Mojo tries to play a file that is never received.
