Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Nov 5, 2016 at 12:51 PM Post #25,202 of 42,916
  Seriously considering buying a second Mojo as a gift through Amazon UK and having it shipped here to the states. The shipping speed you received was impressive. Was that normal shipping or Global Priority may I ask? BTW, is the Mojo you received the newer vintage with the inscribed housing or like mine with the sticker - just curious.
It was Amazon Global Priority.
The logo is inscribed.  Here is a pic without the case:
Nov 5, 2016 at 1:00 PM Post #25,203 of 42,916
@EagleWings, how do you get digital out from Sony a15 ? if it can be used as transport, it can be on of the the cheapest transport to mojo !
I have not tried this cable myself, but I got this link from one of the threads here on Head-Fi a while back:
Edit: Apparently this cable does not work with the Mojo. Please see below post for the link to the cable to connect Sony Walkman to Mojo or Hugo
https://www.amazon.com/Custom-Walkman-Digital-WM-Port-Degrees/dp/B00YWEHSQY/ref=sr_1_1?ie=UTF8&qid=1478365180&sr=8-1&keywords=sony+walkman+dac+ha2+cable
Nov 5, 2016 at 1:08 PM Post #25,204 of 42,916
Please don't buy that cable to use a Sony DAP with Mojo - as quoted in post #3:
  This cable looks really interesting also!
http://www.amazon.com/Custom-Walkman-Digital-WM-Port-Degrees/dp/B00YWEHSQY
This will not work with HUGO/Mojo. It works only with OPPO HA-2. There's a 20K Ohm resistor between pins 4 and 5.
To successfully connect a (suitable) Sony DAP to Mojo, you will need a 'Sony WMC-NWH10 USB Conversion Cable for Hi Res Audio Output'
http://www.amazon.com/gp/product/B00FF086HE
Nov 5, 2016 at 1:10 PM Post #25,205 of 42,916
Nov 5, 2016 at 1:13 PM Post #25,206 of 42,916
Lavricable is NOT working with Mojo, iPhone 6S+, iOS 10.2 (14C5062e) version of the software.
Nov 5, 2016 at 1:14 PM Post #25,207 of 42,916
@EagleWings
I see you have the X3ii and Mojo, how are you liking that pairing? I just bought the X3ii and a cable from PETEREX coming soon I just need to order a Mojo. I just had one not to long ago and traded it for Opus#1 and now I want a Mojo again. You live and you learn I guess.
Nov 5, 2016 at 1:17 PM Post #25,208 of 42,916
FWIW, I wouldn't recommend using a Sony DAP with Mojo, if it's intended for regular portable use.
I used a Sony NW-ZX1 with Hugo for a week (thankyou @ OK-Guy) and I found 2 things:
  • The ZX1 battery life was appalling when feeding a digital signal to Mojo. I don't know it this was due to the decryption (or whatever it is Sony have implemented) guzzling CPU cycles, or some other bus-related reason, but, as many have noted, Sony DAPs just don't have good battery life when used as digital transports to DACs / DAC-amps.
  • The reliability of the digital connection was superb - I was very impressed with how rapidly (almost instantaneously) & reliably the ZX1 would connect with Mojo - it never dropped the connection at all. Never.
So, good & bad...
Nov 5, 2016 at 1:21 PM Post #25,209 of 42,916
I don't understand why you would pair ZX2 with Mojo. The ZX2 is portability supreme with one of the best sounds you can get.
Mojo is also one of the best sounds you can get, however is different to me than the ZX2 sounds. I would not pair them up. However I do have all the music I need on my iPhone. That is a far far better streaming device than the ZX2 will ever be.
Nov 5, 2016 at 1:26 PM Post #25,210 of 42,916
@EagleWings
X3ii is one of the best transports for the Mojo in the price range IMO. The UI as well as the co-ax connection to Mojo is reliable and stable.
Nov 5, 2016 at 1:34 PM Post #25,211 of 42,916
Cool, thanks. I was looking at buying the M1 but I think its to new and want to see the issues its having fixed first. Also, I want to see how that USB jack is going to hold up over time.
Nov 5, 2016 at 1:42 PM Post #25,212 of 42,916
Crap.  I ordered one a few days ago.
Nov 5, 2016 at 2:21 PM Post #25,214 of 42,916
Hi guys, just curious, is there any audible difference between 16 and 24 bit audio? I currently stream tidal hifi, is the difference between 16 bit and 24 going to be easily noticeable? I dont know where or how I would listen to 2r bit audio?
Cheers
Nov 5, 2016 at 2:38 PM Post #25,215 of 42,916
Unfortunately the judgement of audio quality is completely different (much more difficult and subjective) from video quality, say 4K video is clearly better than 1080P, but it's not necessarily the case when it comes to the comparison of 16bit and 24bit audio.
