mathi8vadhanan
Can anyone in the US recommend some optical solutions to plug the Mojo into a AK120ii?
Sysconcept is cheaper at $58. Moon audio's form fit cable is $100.
I am having problems with my Mojo and my JH Audio JH16Pro CIEMs when I use optical or coax or have no USB connection. Anyone hearing this too? Wondering if I have a bad Mojo...
Without any input cables connected, or optical or coax connected, I hear a high pitched warbling noise in the CIEMs. If I play music via optical (driven by MBPR) or coax (via Fiio X3ii) I still hear some noise during quiet sections (e.g was listening to John Lee Hooker - Chill Out) though not as loudly. If I connect using USB (both MBPR and iPhone via CCK) I do not hear the noise at all -- ie. the USB mutes the noise.
I don't hear this with my other headphones (LCD-X, EL8Cs).
Since I have a Hugo too, I tried the JH16Pros with the Hugo and didn't hear any noise at all -- the JH16Pros and Hugo are completely silent when connected via optical (using the same optical connector that came with Hugo) or coax.
I vaguely recall people saying there was interference with phones, but I'm not hearing that.
So anyone heard anything similar? Pretty disappointed with this -- the whole point of getting the Mojo in addition to the Hugo was for traveling with the JH16Pros...
Why 5mm, what's wrong with 2mm cable? Using indoor only.
The 5mm just use a thinker shielding and sturdier than 2mm.
I have both you want the cable that is thicker because it has a nice protective jacket the thinner one is with everything stripped off except for the very last cover over the optical cable.
Asked this a couple of days ago but got lost in this fast moving thread.
If I add an ak100/120 to my mojo what kind of % increase will it give in sq over my current Android/mojo setup?
I know this will be dependant on the user but is there much of an increa or is it purely form factor and function?
For me, having come from an X5 and a Hugo, it isn't about SQ so much as form factor, so pleasurable to have a stack that you wouldn't mind getting out of your pocket on the train, not to mention the bands don't get in the way of the control interface
Ordered the cable on friday and it arrived today from sysconcept,service was first class and its cured my hires toslink woes
None! If you have an iPhone or smartphone, use that.
Likewise. I was using an AK240. I could have taken my Hugo with me, but even managing it on a plane, with all the cables and hassle, was a PITA. I might still get an AK100 and a 2mm Sysconcept set-up for travelling. That way I can easily play high-res files, which I can't from my iPhone without more hassle.
That is a Superb combo!!!
FiiO X7 and Mojo.
I'm giving the 2.2mm a try due to the lower profile. This picture from Sys Concept's website illustrates the difference the best.
You can see how much more the 5mm cable will stick out. Hopefully the 2.2mm will be plenty sturdy, and if not the Sys Concept people will stick by their product.
Cheers
Mojo is What HiFi's DAC of the year
If the iDSD is anything like the iDAC2 (which iFi has said they are very similar without the effects turned on) then the Mojo is more natural, coherent, smooth, warm. The iDAC2 is overly bright, forced, thin, hollow, shouty. I'd feel this way compared to other gear as well, not just compared to the Mojo.
correct the Mojo won 'DAC of the Year'... :bigsmile_face:
also worth noting that Chord won What Hi-Fi's Best-DAC in the under £1000 category with the 2Qute... with Hugo retaining its crown in the Best-DAC over £1000+...
Link: http://www.whathifi.com/awards/2015/dacs
