EagleWings
I failed miserably, btw..
Strong are those who can resist the temptation to sneak a quick listen before the 5hr charging completes.
I absolutely love this gadget!
Elegant, compact, good sounding, no fuss, not so many devices do that in this niche market
When paired up with my er4s, it's purely blissful
I've had my unit from day one and it charges in approximately 4 hours (give or take) and I still get 8.5-9 hour run time using the JH Angie or ETHER Flow. I charge with a 2A 5V USB charger and never leave it plugged in for an extensive time. Every now and again I run it until the battery blinks red and then do a full recharge to re-calibrate the battery meter. These practices have kept my battery quite healthy.
I've charged about 3 hours, not sure I want to charge full 10 hours as the instruction stated . It's hard to believe what vapman said that the initial charge matters so much. According to Page 1:
Please note: Instructions advise charging a brand-new Mojo for 10 hours before using, but actually, it is only necessary to charge until the tiny white charging LED goes out. With most brand-new Mojos, this will be around half that. Just trust what the charging LED tells you.
I also have faith in modern battery technology
Chord do approx half charge the batteries before the mojos are shipped, so the full 10 hours is rarely needed.
If Chord did not part charge the batteries, and shipped the mojos with little charge, there is always the risk that the battery would be almost completely discharged, and have entered safe shutdown mode, when the mojo was bought. There would then be thousands of calls to customer services, wondering why the mojos were unresponsive to charging, when first switched on.
[COLOR=FF0000]Please note: Instructions advise charging a brand-new Mojo for 10 hours before using, but actually, it is only necessary to charge until the tiny white charging LED goes out. With most brand-new Mojos, this will be around half that. Just trust what the charging LED tells you.[/COLOR]
I'm not sure why you quoted me. I was one of the first ones to receive a Mojo before the official launch and I have great battery life. I've also been in this thread from the first post so I'm not sure why you are highlighting the information. I was simply stating that my Mojo's battery is still great with the way I use it. Also, it's wise to re-calibrate the 'battery gauge' from time to time. This has proven to fix some users short run time in the past.
