- Apr 18, 2016
Since we are on the topic of Mojo standalone vs with another amp, I think you guys should check out this review of Mojo:
https://headmania.org
I think everyone agrees that Mojo is a fantastic DAC and is considered high end or entry level high end. AMP wise, it's very capable as well but I was wondering what would be an upgrade? I ask this because i'm using audioquest nighthawks with mojo and i find that mojo does't give it satisfying dynamics. I think most people are happy with these combo but i'm a huge dynamics lover and i can immediately tell if a system can be better dynamic wise. I have a Sony MDR100AP as well and it portrays better dynamics and bass control when driven by Mojo.
An upgrade would be if you used bitperfect mode. If you already use that, then start looking for upgrades in the £1000+ price range.
I owned Nighthawks for a couple of months and did not think it lacks anything with Mojo. (25 ohms headphone lacks dynamics with Mojo? Come on.)
(Although, note I sold my Nighthawks as it was not my cup of tea. I liked the bass and the velvety smoothness and comfort, but the mids and treble just did not make it up for me. It was sort of a closed in experience even compared to TH-X00s.)
EDIT: Imo you are rather talking about headphone preference than DAC dynamics.
Actually, the impedance does not tell the whole story. I have a Rhapsodio Galaxy which is rated at 16 Ohm and 112 dB sensitivity. At 16 Ohm my iPhone, Mac or Fiio X3ii should not have any trouble driving it and they don't. Galaxy gets pretty loud on all these devices. But it lacks those dynamics, depth and sounds harsh. Galaxy loves power. Mojo provides sufficient power to drive it well. But it doesn't end there. A couple of Galaxy owners have confirmed with me personally that, the Galaxy scales higher with powerful amps. The maker of the Galaxy himself uses his IEM with his desktop amp to get the best out of it.
Along the same lines, it is possible for a low-impedance headphone/IEM, to sound better/scale higher with an amp that has a higher output power than the Mojo.
I am also wondering if anyone uses Mojo with LCD-2 (2016 edition)?
Opinions?
Audeze, themselves?
I am also aware of this.
Impedance is just one aspect and can be very relative.
I believe, Mojo can start to be questionable at 300 ohms regarding dynamics. Some people find it sufficient, some do not.
But Mojo at 25 ohms? I think all grey areas are vastly covered in this case.
Ok, this thing starts to drive me crazy.
I use Mojo as desktop DAC with AQ Cinnamon. The cable connector does not have the snug fit, like some cheapo usb cables do. It moves around, and when I move Mojo it often loses connection, which results in an error message in Foobar. Repositoning the cable (while staying connected to Mojo), closing the error message and restarting the track solves the problem.
But this happens far too often, when I move Mojo around.
Chord says, they have standard usb inputs. AQ says they have standard usb plugs. So, there is noone to blame, but I am still going crazy due to loosing connection after the slightest movement of the unit.
What would you guys do in my shoes?
I obviously hear big difference between the stock usb cable and the Cinnamon. Having no better idea I thought, I'd try some other cables in Cinnamons price range or lower, and see if they stay in place. (And selling cinnamon, although I like the sonic improvement it brought.)
Many thanks for any response.
Opinions?
