FWIW my Fiio L19 cable works with my iPhone SE running iOS 10 and connected to Mojo. The cable is finicky as all hell (same with iOS 9) but I was able to get it to work.
Your recommendation is saved in my notes, I'll deal with cables after the speakers but will have the cash to do it properly. Actually given that there are a bunch of used active monitors half price on eBay I think I'll be getting the speakers first of all, cans and mojo to follow later.
For all Mojo users here are the jack-to-phono (J2P) cables What Hi-Fi recommend.
QED Profile comes in J2P - five stars £18 (maybe discontinued)
QED J2P - five stars - £50
QED Reference Audio J2P - five stars - £50 (I think discontinued - still purchasable)
QED Performance Audio J2P Graphite. Don't know a rating but the phono to phono Performance audio gets 4 stars.
Chord iChord. (ebay now only I think.) Five stars.
My Reference Audio added to the transparency, on the road to taking the speaker out the equation. Meaning the speakers appear to disappear. Music is transparent and appears just to be in front of you, rather than being made by speakers. Overall a good upgrade.
Without the Reference Audio J2P I bought, my BT3 boomed a little somewhat at certain frequencies. The sound was heavier and slightly boxy sounding also. It was slightly less nuanced, and sparkly parts were slightly less clear.
I also bought some Chord Clearway, which made the image just noticeably more balanced, and clearer.
If it plays Hi Res natively you shouldn't need an extra app. you will need some sort of cable to get from your phone's digital output jack to a micro USB jack on the Mojo.
