Hi! How is the Chord Mojo sound and amp section compared to the Acoustic Research AR-M2?
Thanking you in advance!
Roi
Roi
Roi
- The Mojo does not have an output amplifier section
Roi
Hi thanks, so the AR-M2 is the ideal partner for the Beyerdynamic T1 gen 2s?
Mojo, Hugo, TT, Dave all have the amp and dac archetecture as one on the motherboard. There is in effect an amp.
There is the Current to Voltage output like all DACs, but the analogue filter and Voltage boost amp are not required, as I understand it. Hence, it's more like a variable line-out (with digital volume control) than an amp.
True and while output in watts into 46 ohms are similar between mojo, Hugo, and TT after testing and or owning all, I can say the scale slam and mid detail are not the same. Mojo
Ok, but nobody said they sounded the same. Just clarifying the earlier 'no amp' comment.
It was not implied that they were the same but output in a technical sense is about a half watt for all three, in refrence to the amp question for mojo.
Ideal partner is also theoretical construct of opinion. Other than testing yourself sorry to interject
Just curious why your bringing the other Chord gear to the conversation is all. The guy was asking about a comparison between the AR-M2 and Mojo, not Hugo, and Hugo TT comparisons. We'll end up talking in circles and no one is 'wrong' here. I read Rob's comments in the TT thread referencing the output @46 Ohms. It just has no relevance to the initial question.
Hi, I don't have the option to test, unfortunately!
