RPB65
- Oct 11, 2015
- EagleWings
- Thanks for the above post! I'm on Amazon having a looks
Its your lucky day. The target had Santiago 20i and Santiago 20ii. Both can hold a Mojo and a USB cable but is somewhat a tight fit. Santiago 20i is slightly smaller than the 20ii. 20ii has a foam pad inside, that takes up a lot of space. It is held in place by a dual side tape and looks like you can take it off easily. Without the foam pad, 20ii should have more than enough space for a Mojo + USB Cable and some wiggle room.
Hope that helps!
- EagleWings
Thanks again, EagleWings. Who'd thought Target had a good camera case selection.
I was looking for a fix in this thread but wasn't sure what keyword to search for...
I just got my Mojo and have a problem with the first half-second of every new track being cut off. I'm using it with a MacBook Pro Retina and the problem happens with iTunes, Tidal, Spotify, and Vox (every program I've tried). I don't have this problem with my DragonFly Black, Apogee Groove, or Apogee Uno.
Is there a fix for this?
Also, I noticed clicking sound when scrolling my trackpad in Safari. I dropped the sampling rate in the Audio/MIDI Setup and that corrected the problem. I'm now running it at 44.1K
You should relax - The only non-official US dealer i remember being mentioned is Massdrop. Several other legit dealers get regularly mentioned, and i think the only stress was occurring in the first few pages of this thread, during the first few days that Mojo was on sale (and in very short supply). If someone saw the mojo in stock on a webpage, and then went away to make a coffee, the dealer was already sold out ten minutes later.
The supply chain to dealers normalised itself months ago.
Enjoy the weekend compiling your playlist of music to test your new Mojo, then make sure you headphones or amp works, that you have the correct cables, and then sit back and enjoy a beer.![]()
I just got my Mojo and have the problem with the first half-second of a track is cut off. It happens on a MacBook Pro with Vox and Tidal. I haven't tried other apps yet.
Chord really needs to provide a firmware update to fix this. I don't have this problem with any other DAC.
Mojo in common with Hugo has a mute function . This occurs when the usb changes sample rate or switches to dsd. This is to eliminating the huge bangs that some os creates. Losing half a second is better than losing your headphone drivers.... Rob
The problem of muting the initial start is due to certain OS and apps - when the sample rate changes, the data in the buffers get sent out at the wrong rate. When you switch from DSD to PCM you then get a loud bang, or track played at the wrong rate for a period. Now this fault is in the app, its absolutely nothing to do with the DAC.
So to fix the apps problem, if the sample rate changes, I force a mute for 0.5 seconds, so that you do not hear these noises. On some apps, you can force a small silent period at the beginning and this solves the issue.
If I didn't do this I would have people complaining about bangs thumps and music being played at the wrong rate. Better silence than shots being fired off!
Rob
Some applications allow to set a delay in milliseconds, to overcome this.
Your computer will consume quite a lot of CPU resources if unnecessarily upsampling, by default.
What resolution music files are you playing?
Mython,
Thanks for the reply. That sucks there's no fix. I can empathize with the problem Chord was trying to solve, but I'd prefer to accept the risk of a signal spike to my headphones over losing the first half-second of every track I listen to. I haven't had any problem with my other DACs. I'm shocked that more people aren't outraged by this limitation, and rather limit using the Mojo to certain programs where the problem doesn't exist.
I'm not sure what apps let's you insert a silence before every track, but I'd like to have the choice to use any program. Can I configure this in iTunes, Spotify, or Tidal - or do I have to buy an expensive program that doesn't integrate with my sources of music?
Chord should offer a firmware upgrade that allows owners to switch this behavior off & on.
The funny thing is I was planning to demo the Mojo to my friends - but now I'm embarrassed. "You paid how much money?! And it drops the first second of every track?!? LMAO!"
Mark
P.S. I'm not using any fancy bit rates: 256Kpbs in iTunes, and the high-quality settings in Spotify and Tidal. In Vox, I'm using AAC lossless rips of CDs, but I haven't ripped much of my library to AAC yet.
Rob
I was asking that in relation to the clicking - this is not uncommonly experienced by some people, just like you, who unknowingly have software upsampling to 24 bit 192khz, on-the-fly, by default. That takes quite a bit of CPU resources, and sometimes the CPU runs out of steam, or the buffering methodology employed by the software is not very efficient.
I've just answered your post in the Mojo issues thread - please try not to double-post.
Cheers![]()
- EagleWings
yesterday got my chord mojo back . I kept it somewhere during the transfer. when I was not having mojo I tried hqplayer to upsample and listen through the sound card of laptop. sound was much better than j river and foobar upsampler. so after getting mojo back I was curious as to how would an upsampled output of hqplayer sound through mojo. after trying so many filters and sample rates in hqplayer, I found foobar bit perfect output to mojo to be the cleanest as have been suggested by chord too ( don't use any resampler with mojo ). hqplayer upsampled output while good with sound card of laptop but with mojo the limitations of hqplayer become obvious. it added artificial detail which added grain to the sound (or vice versa). switching back to foobar in bit perfect mode sounded cleaner. surprisingly j river even in bit perfect mode ( no DSP and direct connection using asio) sounded harsh as compared to foobar. I don't know why foobar every time sounds better , may be it's lighter than j river or may be j river even in direct connection mode is performing some kind of processing .
