- Feb 11, 2008
1) Do you mean the Mojo HARDWARE is making a clicking noise, or do you mean you can hear a clicking sound in the audio signal Mojo is producing?
2) What device are you feeding Mojo with? (laptop, smartphone, etc,)
The audio signal is producing a clicking sound, I tried unplugging the charger which made no difference, unplugging the mini jack to my amp completely eradicates the noise which tells me that it's from the Mojo, my sound card does not make this issue when plugging in speakers or headphones directly. I also tried switching the USB plug to my desktop, and also trying to plug into a different USB outlet which also did not change anything.
This is strange since it did not occur prior to the move. I packaged the Mojo inside its original box, inside a cabinet that's very well secured since it contains all my audio equipment, so damage is also out of the question. Only thing that may happen during the move is the heat inside the moving Penske truck, but all my other electronics, including more sensitive ones, are not damaged at all.
The clicking noise ONLY happens with 3D images, and does not happen outside of the game in windows, or if the game intro menu is in 2D. It also seem to sync with the images on screen. For example, changing the menu inside game seems to change the frequency and intensity of the noise. Nothing is done to change the drivers or software settings. This is so weird...
Luckily it's still under sonic electronix's 3 month return policy and if I need I can swap out for another one.
Well one possibility is that your graphics card may be emitting increased RF when it's cores are under load, or inducing more RF in other components (such as your PSU) of your PC, when the GPU is under load. Mojo might be receiving some of that RF.
If your digital cable will permit it, try moving Mojo as far as possible from the PC. Also try a ferrite choke over the same cable.
Let me know what you find out.
