with windows 10 goto the search bar and type sound. When icon pops up click on it and you will get a menu. On playback tab goto chord mojo etc and right click and highlight enable. That's it.
Isn't AISO the preferred choice as the Chord Windows driver has a more direct connection to the Mojo this way? Disclaimer, I don't run any audio through my Windows workstations, but from reading the forums this is what I've gathered.
I was hoping someone would tell me if that worked. I have a UBS 1.0 powered hub, but that Mojo does not work through that. If I recall correct my Meridian Explorer didn't either. I think it's because they need USB 2.0 to run; I think it's a bandwidth thing.
Don't know why. I am able to choose mojo Wasapi with my Jriver running windows 10. Maybe try disabling all other audio devices except mojo (like realtek etc). I now use a Tidal with Roon and it's much better than jriver. If you can't get it to work, there are other options btw.
Sorry about being obtuse but we are still at least four months from showing working samples to the press so it's too early to show our hand at this stage, but as I've implied before I hope and think all of you will like what we've been beavering away at.
I understand that this is a massive thread and I am unsure if this has been discussed here in the past, but can anyone tell me how the Mojo matches up with the LCD-2F? I am reading and hearing a lot of uncertainty if the Mojo has enough juice to drive the LCD-2s adequately.
Sorry,not doubting but wondering...
Eager to learn.
Do you need more than 500mA in order to establish protocol communication ?
Unclear for me since Mojo is powered by a dedicated usb power input.
Sorry - Maybe I misread the original post that I quoted...
For powering the mojo, USB1 isn't enough, also - for playback, I also believe there are issues, and that it can only be USB2 that carries audio (can run driverless), or - USB3, albeit for the newer, higher bitrate files - a driver is required.
Hi,
My two cents point of view:
- a fiber transport is imune to external interferences. Therefore almost no worries for running your cable.
- a fiber cable is sensitive to dust/dirtiness at extremities
- a fiber cable ia sensitive to small radius bending ( extreme bending).
That said it is more likely that those clicks may come from your DAB tuner if not source or streaming processes.
At which sample rate is mojo playing your DAB tuner?
I need to try again n that station. Classical music allows us to turn up the volume without being blasted out. Thus we can hear quiet clicks. Major issue though if it's the Mojo. I just don't get it, because I have listened to Classic FM before and not noticed it.
Eager to learn.
I made a post to answer this but it's not here. Maybe a mod deleted it.
I will try again though because I think it is relevant to the Mojo.
This is what the What Hi-Fi review of the Meridian Explorer says about requiring USB 2.0.
Quote, "
Furthermore, the Explorer employs USB audio class 2.0, which allows full native playback of high-resolution 192kHz sample rates. This is opposed to audio class 1.0 –as is found in the HRT microStreamer, for example – which limits the sample rate to 96kHz, with higher sample rates having to be downsampled."
Read more at http://www.whathifi.com/meridian/explorer-dac/review#q2iX4Kesd3TtEP32.99
The Mojo will still get a 5V signal on it's audio data line in, on a USB 1.0 hub.
It seems more likely that the issue is with bandwidth, as stated in the What Hi-Fi review of the Meridian Explorer.
Quote from Arpiben's post. (Post 20297 on page 1354.)
" Nevertheless,that is the reason why Chord in Mojo's manual is writing the following:
Connect Mojo to the host computer, phone, or tablet by inserting a USB lead into any available USB socket. To support high sample rates (96Khz and above) the USB socket on the computer must be USB 2.0 or above."
There is a group of people who use low noise PCs and run Linux system instead of Windows. They say they have modified the kernel of Linux extensively to simply things and the result is that the sound is much better than a Macbook. Have you guys heard of that and would you recommend that to Dave users?
Louis, do you know the name of the Linux distribution that they created? Every year thousands on new 'forks' of the linux distribution are created (many by students enthusiastic to improve their linux coding skills, and some by enthusiasts who need a tailored/improved version of linux for a specific need/activity), so some info regarding a distribution name, or project name, helps the search.
Your post has encouraged me to retrieve this bookmark to the AudioVisual Linux distribution that i spotted last year. I wondered if it was a better operating system than windows for music playback - but this distribution appeared focused on musicians and music producers, so i forgot about it. Today i read that the 2016 distribution is a complete revamp of last years version, so i will review the new user manual.
