miketlse
- May 8, 2016
Maybe a USB 2.0 hub will run the Mojo then.
Going back to my other old issue of random clicks, I noticed something a little odd this morning. I was listening to Classic FM on my DAB tuner though the Mojo, and had volume fairly quiet. I was getting a lot of clicks; like maybe every fifteen seconds. This is easily the highest count. The highest number of clicks I got before was about ten in one CD album.
I never even noticed clicks before on the radio. It could be interference. I am now running Mojo on my desktop connected to a DAB tuner on my desktop. I run an cheapy £2 optical to connect. ...I do wonder if I never noticed clicks before with the tuner because I lay music which covers the clicks. However I am sure I have played Classic FM quiet before. The optical cable does run under the tuner and in front of a Q Acoustics BT3 desktop speaker.
Remember with the Mojo that you have two USB sockets.
1 - The charging socket needs at least 1A, so you cannot charge Mojo from a USB 1.0 socket.
2 - The data socket does not draw any current from the 5V line, so you could in theory connect to a USB 1.0 socket. The big question then remains as to whether the bandwidth would be enough, or whether USB 1.0 limits you to MP3, standard CD, or whatever.
The Meridian Explorer 2 requires nominal 5V at <500mA, so in power terms you could run it from a USB 1.0 socket. However that does not answer if USB 1.0 provides enough bandwidth for Hi Def music.
It should not make any difference if you run an optical cable under a tuner, or near to a speaker - the signal is optical, and not electrical.
When at home I always run Mojo on optical, because I got fed up with pops and clicks using USB.
We don't have DAB radio in france, so I cannot test how my Mojo works with DAB. However i do remember that when in the UK, I lived in an area of bad DAB reception, so that it was unusable inside houses.
I do remember one of the Mojo posts recommending cleaning the end of optical cables, to remove any crud that is interupting/corrupting the signal. That would be a low cost/hassle experiment for you to try - if it fails to improve, then you have lost nothing.
