I'm finding my Mojo a bit of a pain with Windows (10) and wonder if a fellow Windows user could confirm if what I'm seeing is normal?
I have my Mojo connected via USB and when I view audio devices in the Sound tab I see 'Chord Async USB 44.1 kHz-768kHz' as the default device so that looks okay. However, when I right click and select 'properties' and then 'supported formats' the only sample rates I can select are 44.1, 48.0, 88.2 & 96.0 kHz. Does that look right or should I be seeing 192 kHz and upwards too?
I've also selected the default format from the 'Advanced' tab as 2 channel, 16 bit, 44100 Hz (CD quality) as most of the files I'll be using will be CD's or from Tidal. Correctly the red light displays on the Mojo.
If I try and play some HD Tracks samplers (88.2, 96, 176, 192 kHz etc.) using Foobar the bitrate light stays fixed at red unless I set the default format to something higher. Switching to 2 channel, 24 bit, 192000 Hz for instance correctly turns the light blue. I had hoped that by doing this the I would then see the light change depending on the bitrate of the incoming file but irrespective of what bitrate of file I play the light on the Mojo remains blue. Is there a way to get the Mojo / or PC to avoid up-sampling, which I presume is what's happening, all material to 192 kHz or do I need to manually set the default format each time?
I also tried playing a DSD 64 file (.dsf) but got an unsupported format message. Perhaps that's one for another day though...walk before you can run etc.
Thanks very much for any help. Happy to add some screen grabs if that helps.
Edit: should add that I unzipped & installed Chord's Windows driver + the ASIO 64 (iirc) add-on before attaching the Mojo to my PC.
