- Feb 11, 2008
i thought i'd read somewhere in which mr watts preferred a toslink connection...but for what sort of purpose I'm not sure.
LOL - I reposted Rob's quote just 3 pages ago
Also discussed here:
Digital transmission is based on SPDIF standard which transmits data and clock information as an encoded signal usually using PCM, that information is decoded on the Mojo into data and clock signal so it's important that the encoded information be jittered free and not degraded over short distance.
The USB transmission on the other end is a device to device transmission mechanism using an encoding scheme and handshaking mechanism, it is usually stream based so more tolerant to poorer wire as frames are transmitted and decoded from the source to the target device. The target device will reconstruct the data and clock signal from the frame and then feed it to the DAC to be analog reconstructed and eventually band pass filtered to remove any residual high and low frequency signals out of the audio band.I still think you need to keep the USB cable short but it is more tolerant of longer lengths up to a limit.
To make a story short, the short USB cable is fine but an analog cable used as a digital one is just a bad idea. Again, that's just my opinion.
Just to clarify:
1. SPDIF decoding is all digital within the FPGA. The FPGA uses a digital phase lock loop (DPLL) and a tiny buffer. This re-clocks the data and eliminates the incoming jitter from the source. This system took 6 years to perfect, and means that the sound quality defects from source jitter is eliminated. How do I know that? Measurements - 2 uS of jitter has no affect whatsoever on measurements (and I can resolve noise floor at -180dB with my APX555) and sound quality tests against RAM buffer systems revealed no significant difference. You can (almost) use a piece of damp string and the source jitter will be eliminated.
2. USB is isochronous asynchronous. This means that the FPGA supplies the timing to the source, and incoming USB data is re clocked from the low jitter master clock. So again source jitter is eliminated.
So does this mean that any digital cable will do?
Sadly no. Mojo is a DAC, that means its an analogue component, and all analogue components are sensitive to RF noise and signal correlated in-band noise, so the RF character of the electrical cables can have an influence. What happens is random RF noise gets into the analogue electronics, creating intermodulation distortion with the wanted audio signal. The result of this is noise floor modulation. Now the brain is incredibly sensitive to noise floor modulation, and perceives this has a hardness to the sound - easily confused as better detail resolution as it sounds brighter. Reduce RF noise, and it will sound darker and smoother. The second source is distorted in band noise, and this mixes with the wanted signal (crosstalk source) and subtly alters the levels of small signals - this in turn degrades the perception of sound stage depth. This is another source of error for which the brain is astonishingly sensitive too. The distorted in band noise comes from the DAP, phone or PC internal electronics processing the digital data, with the maximum noise coming as the signal crosses through zero - all digital data going from all zeroes to all ones. Fortunately mobile electronics are power frugal and create less RF and signal correlated noise than PC's. Note that optical connection does not have any of these problems, and is my preferred connection.
Does this mean that high end cables are better? Sadly not necessarily. What one needs is good RF characteristics, and some expensive cables are RF poor. Also note that if it sounds brighter its worse, as noise floor modulation is spicing up the sound (its the MSG of sound). So be careful when listening and if its brighter its superficially more impressive but in the long term musically worse. At the end of the day, its musicality only that counts, not how impressive it sounds.
Rob
In addition to these quotes, there are a few other bits & pieces, on the topic, in post #3:
- Informative posts by Rob Watts¬
- Is one of the input types better than the others
but it's interesting to also note:
Just to make it 100% clear - the USB input will measure absolutely identically to the coax or optical inputs if the USB data is bit perfect.
I have set up my APX555 so that it uses the USB via ASIO drivers, and I get exactly the same measurements on all inputs - 125 dB DR, THD and noise of 0.00017% 3v 1k 300 ohms. I have done careful jitter analysis, FFT analysis down to Mojo's -175dB noise floor, and can measure no difference whatsoever on all inputs (with the APX always grounded on the coax).
If somebody does measure a difference its down to mangled data on the USB interface (or perhaps poor measuring equipment - Mojo is way better than most test equipment). Mojo can't convert 16 bit data back to 24 bit....
Rob
