I hear you and I agree - many of my tracks are varying format as well. That's great to hear that Mojo lifts them all! (mine shows up on Tuesday, so I haven't heard it firsthand)
Canali said he was buying FLACs, so I was merely pointing out that if he's going to get an iPod he'll need to invest in a player that plays that format as well. Re-reading my post, I don't I think I worded it that well.
But question for you while I have you on the line -- you say the "trick" is to feet it a bit-perfect signal. For the layman, how is that accomplished: a setting in the player? A cable?
Your wording was just perfect my friend. I just wanted to get the bit-perfect aspect across the table as it is a critical thing for Mojo to sound it's best.
About outputting bit-perfect. What device will you be using?
Windows: I use Foobar2000 on my work PC and you need install a WASAPI component (plug-in) to do bit-perfect. If you are willing to spend some $$, there is the Jriver application that many love.
Mac: I am currently using Vox application. It is Avery basic application without any bells and whistles but is capable of doing bit-perfect. It is just a change in setting to get bit-perfect. But there are tons of options for Mac if you are willing to spend some $$. Audirvana +, Amarra, Jriver are some of the popular options.
iOS: first you need an Apple Camera Connection Kit cable to do bit-perfect. Based on what I have gathered, iOS seems to do bit perfect as long as we are using the CCK. But if you are using Apple Music, the wifi signal strength can impact the quality of the music. Meaning, when you are connected to a poor wifi network, the quality of the file that Apple Music receives may be not the best. Something to think about. Not sure if Tidal behaves the same way. if you just have 16/44 FLACs, Vox for iOS can work. But once again, it is a very basic UI without bells and whistles. And you already know the answer for playing native Hi-Res files: Onkyo HF player.
Android: You need an OTG cable and the device should be OTG capable. There is a 3rd party app called the UAPP that seems to do bit perfect for Tidal streaming. If my memory serves me well, in all other circumstances, android up-samples the files. But I have not done a thorough research on the Android side. You may want to research this thread to get your answer.
Hope this helps. And as you will be receiving your mojo this Tuesday, Happy Listening
