Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Oct 23, 2015 at 10:03 AM Post #1,742 of 42,916
Anyone ever tried using a 128gb micro SD in an AK100?
Was going to ask on the AK100 thread but there's been no action there for over a month.
Thanks!
Can let you know next week as have a couple of 200gb cards on route - if that helps?
Oct 23, 2015 at 10:09 AM Post #1,743 of 42,916
Can you try to different DAC ? to see if the Mojo or the Questyle or the Cable has the issue?
Tried it on another device. Computer -> external sound card -> optical out to mojo. Nothing as well. There's sound coming out from the headphone out from the external sound card. Guess what it's left to do is to find another optical cable to try.
Oct 23, 2015 at 10:23 AM Post #1,746 of 42,916
That's why I said it probably doesn't help, but... Well, it might
Oct 23, 2015 at 10:28 AM Post #1,748 of 42,916
Sorry, yes, in mobile land is a bit of a PITA with multi quotes, but for you the 200gb cards should work fine :)
Oct 23, 2015 at 10:34 AM Post #1,750 of 42,916
You're all crazy using these expensive DAPs where a smartphone will suffice. Especially Duncan.
look nicer and no rf magnetic interference and optical in -
Oct 23, 2015 at 10:43 AM Post #1,751 of 42,916
Thanks!
  Hi mscott58, I do have a 128 SD card running in my RWAK100S and it works fine. Just slot the new card in first for the AK to first format it and you're good to go.
Oct 23, 2015 at 10:46 AM Post #1,752 of 42,916
I noticed something odd and I wondered if anyone had a solution. My Mojo is telling me that my Spotify stream is being output at 192khz out the usb even though Spotify is only 44.1khz. Any way to change this so it outputs the native Spotify sample rate? My phone is a Oneplus One
Hi Rowethren,
I think this is due to the 1+1 running on CyanOS which is based on stock Android, I think I remember reading that they introduced all audio being up sampled to 192Khz when Lollipop was released. I'm a 1+1 owner and my current DAC at home reads 24 / 192 when I use Spotify / Tidal / Deezer & Qobuz streaming apps.
@DanBa is a bit of an expert from what I've read on other threads & posts on Head-Fi in the past, I'm sure he can explain it better than I have.
Hope this helps :)
Oct 23, 2015 at 10:47 AM Post #1,753 of 42,916
Yes there is.
Hi iichigoz, I initially had the same issue with my AK100 when I went to audition the Mojo. I just did a complete power cycle and it worked again. Not sure what it was but it wasn't working initially even though I plugged it in and out of the Mojo a couple of times. Even tried with the Hugo and nothing. After the power cycle and it worked in the first go.
Hope this helps.
Oct 23, 2015 at 10:52 AM Post #1,754 of 42,916
Completely fruitcake me, yup :(
On the bright side, on aggregate the AK120 Titan only cost me £160 after factoring the sale of my ZX2, and if I sell my QP1R, I'll be in profit! (I will tell myself that anyway!)
Damn JF making a device like mojo! ;)
Oct 23, 2015 at 10:53 AM Post #1,755 of 42,916
Hope this helps.
You power cycled your ak? As in u drained the battery and charge it up again?
