ShreyasMax
well-mastered music > lossless file > Mojo > HD 800S = audio nirvana for the detail-obsessed
I'm so freakin spoiled!!!
You definitely are.
Enjoy!
85 decibles, at least in my A12 CIEMs is extremely loud, I listen more in the 10-15 click range..
Slightly off topic. Funnily enough I tried Tidal yesterday on my Iphone, took the free trial to find what all the fuss was about.
Comparing to Spotify, I opened up identical tracks on both apps, making sure they were exactly the same track from the same album.
Genres varied between Jazz, Classical and Dance.
Rather than play one track on Spotify then play the same track on Tidal - (by the time you restart the track your expectation bias kicks in) I did this..
I set up Spotify to play the first 30 seconds, 00:00 - 00:30 and then had Tidal play the next 30 seconds, 00:31 - 01:00 and so on to the end of the track.
I found there was no difference in audio quality between the apps when identical tracks were playing. It sounded like the same track was being played between both apps, with nothing more than a brief pause in between. I focused as hard as I could on different aspects of each track, listening to details in each instrument, listening for slight timbre differences, nada.
i urge anyone who uses either Spotify or Tidal to take out a trial with the other app, bouncing back and forth between apps in 30 second snippets, in random order. Don't leave it too long between each 30 seconds, switch as quick as you can. Ensure the wave volume of both Spotify and Tidal is set to maximum (bit perfect) and only controlled via the Mojo.
After a while you will begin to forget which app is playing the track.
A true testament that there is no perceivable difference. Data wise, maybe, but data that my brain can interpret?
Gear - Mojo, stock He-500 (velours), iPhone 6. App settings - Tidal - Hifi setting / optimized playback disabled, Spotify 320Kbps, normalisation disabled.
Those of you guys who have mic cables with your IEMs/CIEMs, can you take calls through mojo on Android? I'm looking at getting a slightly longer cable and have a choice between mic and no mic and would only get the mic cable if it meant I could take calls through Mojo. I'm using S7 Edge and running marshmallow.
How do you rate the Mojo compared to those other top tier DAPs you have in the pic? They're the DP-X1 & AK100-II, if I'm not mistaken?
Edit - I'm referring to sound quality comparisons only, of course.
Thanks in advance, cheers.
Been a while since I used an iPhone, so what is the best Music App to feed Hi-def FLAC and DSD to the Mojo at its native bitrate/freq? Is it still only HF Player by Onkyo ?
Most of my listening is Spotify Extreme but do have a few hi-def albums in FLAC/DSD to put on the 64GB iPhone SE.
I did that comparison many times because I'm a Spotify (Premium) fan but plenty of headfiers use Tidal HiFi.
There is no way I can hide the truth: they sound identical to me, and I love Spotify playlists, so I will stick with that one.
By the way, Spotify+Mojo+SE846 sounds very good. Spotify+Hugo+SE846 sounds stellar!
Hugo rules (don't kill me please!)
Really enjoying my Mojo. Would like to know if there is any way to turn off the lights completely. Even when I have them dimmed, they are annoying to have on all the time. Thanks for any help.
