elviscaprice
- Apr 16, 2014
I suppose if they didn't build in any checks if any signal is being received, then it wouldn't switch off by itself, yes. It seems like a rather trivial thing to build in such a check, though, and surely it should be something that such an expensive DAC+amp should have, in my opinion. My stereo amplifier with DAC module is cheaper than the Hugo and can drive some pretty hard to drive speakers, and even it has an auto powerdown option when digital input is used and no signal is received for a certain amount of time.
I wouldn't call it good news that it is recommended to keep a portable device plugged in at all times. Why not just get a desktop DAC and amp, then? Why even bother with the battery?
I fail to see your logic. If the Hugo could power up or down completely on signal received, then why have a switch, which it does? If you followed Rob's posts here on this thread, he already stated that he didn't have the space to allow for any further features without effecting SQ (yet maintain it's small form factor for mobility). Which in my opinion is the most important feature of the Hugo, along with mobility and broad format handling.
As far as it's portable capabilities, the Hugo works fine for ample time off it's batteries, no charge.
The recommendation of maintaining a charge to the Hugo when NOT being used portable is to address those folks who are using the Hugo in a desktop fashion so as to not having to turn off the Hugo and maintain ones settings. It does not harm the batteries to keep the Hugo plugged in. It disengages when fully charged.
