RoundRound
- Mar 29, 2014
Has anyone tried the HD700 with the Hugo? What were they like?
How well (or not) the two interact?
Thanks!
Thanks!
Just received the moon audio silver USB cable. It's lush, just like the positive feedback review states.
I always found the stock USB cable to be harsh, bright, and fatiguing.
In contrast, I absolutely love the Chord Hugo and think it's the best portable DAC/Amp.
PM me. I wrote the guide on SACD ripping, but if you have not too many (and are US based) I can help you rip them.
Here's the guide, btw.
https://dl.dropboxusercontent.com/u/3487125/SACD%20ripper%20primer%20v4.0.1.pdf
Wow,Stupendous job ted_b, on the SACD ripping.. I'm nominating you for a audio Pulitzer, for that one.
Thanks, Rob. I bought this one http://www.firestone-audio.eu/shop/products/allproductslisted/greenkey.php , the only one I can find in Hong Kong in store... I managed to get it working with ipod touch... I can hear better depth with this by using an isolator
will need to A/B a bit more using HD800 without an additional amp
Can you explain how you connected everything together with this isolator, iPod Touch and Hugo? I have the same setup, using the Apple CCK and Vertere USB cable. Does the isolator work without its own mains power? Does it work with the SD and/or HD USB Hugo inputs? As far as I can see from their website, it has input and output USB "A" connections; is that right?
Many thanks for your help!
Tony
This isolator only works with SD USB input thus limits to 16/44/48
it sits between the CCK and Vertere USB cable...
the isolator USB A male connects to the CCK
you can then connect Vertere USB A male to the other end of isolator (USB A female)
we are looking at another isolator that hopefully will work with the HD input but it needs its own (linear, LoL) power supply...
Schiit Wyrd?This isolator only works with SD USB input thus limits to 16/44/48
Schiit Wyrd?
