ALRAINBOW
- Oct 5, 2012
Do you think it will work or I am dilutions I even think it might
Al
Al
All SABRE dac chips are relatively inexpensive. So are its competitors. A commercial DAC component uses off the shelf dac chips because the application notes supplied by their manufacturers make it easy to design and assemble a DAC. One can even order complete dac assemblies requiring minimal support from surrounding regulation and power supplies.
All the comparison of one dac to this dac. While not so easy and yet it is, if you listen to very much live music, compare the sound and intensity to the overall feeling of live music. Which comes closer? I tend to listen to sounds, all sorts of sounds. Hear the sounds of live acoustical and mentally take notes. Why compare reproduced to reproduced when you are trying to compare to real? Compare each to real and then how do they stack up?
Some android phones are ahead of Apple just like before. Apple products still can just play 16/48 while certain Android phones support much higher resolution. What you are seeing is a third party (Onkyo) has made a separate app to stream DSD natively by avoiding what the Apple device's DAC and software. The current ability by Apple devices to avoid its own capabilities doesn't mean it is ahead of Android as natively there are many Android devices that are much more capable than Apple. On the Android, it shouldn't be difficult for an app to ignore the device's DAC (as Android puts less barriers up) and stream out bits (DSD or otherwise) natively to outside DAC as many Android phones have the correct hardware to do so. Someone will update their Android music player to include DSD soon as there are Android music players that currently avoid the device's DAC and stream bits natively to outside DACs.
I think are seeing the Apple currently ahead of the Android in what it is currently able to do with outside hardware/software for two reasons. One, Apple has larger base of users using it as music player given Apple's lead time and history as a music player. Android's fragmented market means an app producer has to worry about the fact that a native DSD streaming feature would only work on certain Android devices etc. Android and more recent Apple product users seem to be using streaming services such as Spotify or music in the cloud storage more than anything else. Makes it hard for us "dinosaurs" who want our music pure and in high rez. However, in spite of all that, I think you will see an Android app do so in near future.
I guess that is somewhat true in the same way the Hugo uses even more inexpensive chips which you pointed out in an earlier post was a silly way to measure value (which I agree with). Now, there is using cheap parts that effect sound (cough some high end manufacturers) and there is using parts that are relatively cheap to the overall cost. The latter is almost always true with well designed equipment as the IP is what brings the value.
The direct stream is chip less like the Hugo
I think it's a choice made not something that has to be
Al
I think there's bug on Head-f: why are we seeing AGB100 and Crashem MPs on the main thread?
Al, not to be pedantic but the only DAC I know of that is chipless is the Lampi DSD-only DAC (analog filters only).
What I meant was no I the shelf chip as in wofson or
Sabre. Sorry as I may when it sounds good my audio vocabulary is really substandard
And my explanations sometimes I am the only one who understands
It. Lamp. Sorry.
Al
Before I repeat my answer to another gent on this thread, possibly I was a reviewer of high end audio gear before Lavorgna purchased his first high end system. Second, I mean no disrespect to anyone here or at his site. My answer however is unwavering:
"OK, let's take it once again, from another angle. Audiostream rated the HUGO in the same class as the $450 Halide. Does that tell you anything? I mean, anything at all? And the Benchmark. Does that say anything at all? Can you now take anything they say seriously? You can?
Maybe, YOU, can. I don't."
If you actually believe that the Hugo is in the same class or design sophistication and has more or less the same sound quality as the Halide, I guess we can simply drop praising the first, for it certainly deserves no praise. In fact, given that classification, it deserves no listen but only a FOR SALE ad at Audiogon.
Given that I wholly do not agree with Lavorgna's ratings - which are plain wrong from the get go - I will go on listening to the Hugo while he can go on listening to the Halide and Benchmark with more or less the same satisfaction.
Sorry, noob here when it comes to digital music but how does the iPhone store DSD music? I thot iTunes quality music was limited to lossy files or at best WAV? Appreciate the guidance..
Subscribed to this thread a week or so ago and made the mistake of ticking the "immediate update" box :basshead:
Besides a full inbox and feeling like I know quite a few of you very well by now, you have also managed to convince me that I really need a £1400 portable DAC.
I hope you all feel proud of yourselves....
