Chord Hugo
- Thread starter harmonix
Crashem
- Feb 5, 2014
It's as I feared concerning a transport only DAP. This is the main issue, IMO, with the Hugo. Basically designed to work with computers even though the Hugo, itself, is very portable. Given the current state of the market, no devices that easily can make use of the capabilities of the Hugo. The setup that takes full advantage of Hugo's capability is basically laptop on the go and nice headphones. For home/desktop use, the Hugo amp does quick cut it and the connections from the Hugo DAC aren't quite there (no balanced for example) to be full desktop DAC replacement (even though the DAC itself is very capable). Finally for true portable use (without computer), there are no DAPs where you aren't rebuying an AMP and/or a DAC.
pekingduck
- May 16, 2009
I am sure it can but the io7 will resample it . If it really can put up some links. That would be nice. But with a iPad you cannot do dsd or even 24/192.
Al
Read this: http://www.computeraudiophile.com/f11-software/free-onkyo-hf-player-app-ios-plays-high-res-direct-stream-digital*-dsd-over-pcm-flac-wav-17917/
You can google it, there are other similar resources on the web.
ALRAINBOW
- Oct 5, 2012
Thanks
Really cool product. But it does not do dsd. It converts to PCM .
How much is it ?
Al
How much is it ?
Al
pekingduck
- May 16, 2009
Thanks
How much is it ?
Al
It's free but to play Hi-res and DSD you need to buy an in-app upgrade for $10..
You can choose to output PCM or DSD-over-PCM inside the app. Check out http://www.digitalaudioreview.net/2013/10/onkyo-hf-player-resonessence-labs-herus-ios-dsd/
CosmicHolyGhost
Exhaustively burning holes in his wallet
- Jun 10, 2013
I am gonna wait until some audiophile DAP can do HD USB audio out for DSD, then I may consider using DSD on the go..
We are almost there, I think.....
Royalorgans
- Dec 1, 2013
what about playing CD files in 44.1K. How do you think the hugo stands to the Antelope Audio Zodiac Platinum playing wav files. Does it do a pretty good job. How does the Hugo stand up against centrance M8 and Schitt audio Gungnir
I want to say a big thank you to dan-gheorghe for his detail review and your photos looks awesome.
I need to get the checkbook now .. Oops where did my checkbook goes...
All DAP/Phones have a DAC & Amp... Chord will be using a Laptop, iDevice & the Sony ZX1 as sources for the Bristol Show.
my small shoulder bag that I purchased for the Hugo arrived yesterday, it will suit my needs entirely... the Hugo/ZX1 will be highly portable now, when I'm home I'll connect it to the pc, simples.
CosmicHolyGhost
- Jun 10, 2013
What shoulder bag is this? Thanks
CosmicHolyGhost
- Jun 10, 2013
Thanks, OK-Guy. I get the idea, I have something similar at home...
Royalorgans
- Dec 1, 2013
what do you all think about the sound quality of this unit vs the Antelope Audio Zodiac Platinum. Would you spend the extra 2,000.00 dollars on the Antelope Audio or would you just get the Chord hugo.
- Feb 11, 2008
Chord Electronics at the Bristol Hi-Fi Show
I sure hope they have more than one Hugo on display! LOL
I reckon there's going to be a small army of people wanting to listen to it (including me).
