warrior1975
- Dec 5, 2013
I hope it's a Hugo Jr. I'd love something that would be truly portable but sounds as good as the HUGO appears to sound.
Yes the next Hugo will just be called H as it will be that small they can't fit the ugo on it and a free microscope to find where you last left itI hope it's a Hugo Jr. I'd love something that would be truly portable but sounds as good as the HUGO appears to sound.
This type of coaxial plug fits my Hugo. However, as weisse muller said, non-open petals plug like the ones used in blue jeans coaxial cable would not fit the hole.
The company has now changed name to Stereolab
Anyone else frustrated on the lack of optical cable suitable for chord hugo? Only one I've found is the sys-concept which is too short for me.
Stereovox XV2. The company has now changed name to Stereolab and their coaxial cable has now been updated. I have no idea how new version sounds or whether the rca plug will fit or not.
http://www.highendcable.co.uk/Stereolab%20Silverstar%2075%20Digital.htm
One thing is certain Xhadow RCA will not fit Hugo's coaxial hole (which is very narrow). Best check with Hugo dealers and see which coaxial will fit etc. I think RCA type similar to the pic of XV2 above (i.e. straight exposed petal rca head) would probably be ok.
the chord company now does coaxial cable 4 the hugo, I've just got a anthem digital tuned aray for the hugo £230.look on their website under new suffCan anyone tell me which cable this is, or provide a link?
I need a digital coax RCA-to-mini connector where the RCA fits the Hugo. I tried a Black Dragon but the RCA is too loose. I know this has been discussed earlier, but I can't seem to find a definite recommendation where someone has actually used it, except for the above.
what's the chord anthem digital cable like for the Hugo,i've got the analogue versions which are really goodthe chord company now does coaxial cable 4 the hugo, I've just got a anthem digital tuned aray for the hugo £230.look on their website under new suff
I've only had it 4 2 days, so still running it in, but 1st impressions r very good, very clean and open,will go into more detail when it's been run in more,hope this helps u out my friend.what's the chord anthem digital cable like for the Hugo,i've got the analogue versions which are really good
