NickedWicked
Anyone tried the Qutest with a Violectric V281?
Yes hardware burn in is for sure a real phenomenon, and something I have fought against for several decades. In the past it was a major issue; DAC's used to measure differently on warm up and when broken in. This was because conventional DAC's - particularly in the 90's - were horribly sensitive to lots of imperfections. Indeed, this was the primary focus to develop pulse array; I wanted the musical benefits of PDM or DSD, but with more transparency, and with much lower levels of distortion and noise. In particular, I wanted every DAC to measure exactly the same, which meant removing lots of sensitivity to different aspects of a DAC design. Thus can only be done at the nuts and bolts level; that's why I had to invent a new DAC architecture, with pulse array.As a new Qutest owner, I wonder if I could please direct a couple of question to Rob Watts?
1. Burn In.
Many users have commented on a "burn in" process, and the sound improving over many hours of use. Do you have any thoughts about this - what is the physics of "burn in", or is it simply a psychological phenomenon whereby a customer simply becomes attuned to their new piece of hardware?
2. Improvements for High Bit-Rate Recordings
I understand how your FGPA algorithms can improve the sound from low data-rate recordings such as CD - I guess you're doing a better job of reconstructing the waveform from a paucity of data - but I'm not so clear why there is still an improvement for high data-rate recordings (such as my brilliantly-recorded and mastered 24-bit 192 kHz Linn classical recordings). I'm comparing against my Naim streamer which, I believe, uses Burr-Brown chips.
Many thanks - and thanks again for the great sound.
Yes hardware burn in is for sure a real phenomenon ...
So I would not be surprised if you hear a change with time; but I don't think it is a hardware issue. That said, the DAC does sound slightly warmer after being on for ten minutes...
As to your comments about HD recording yes the WTA filter will also improve those. This is because 192k as a format is still no where near accurate enough; just hear a 768 k recording! These sound very different to a 192k...
Dear friends,
I think there is no doubt about the "burning" time of our brain ... But I also know that when it happens to listen to a system that I have never heard before, to feel immediately whether I like the sound or not, before having even "burned" the brain!
In the case of qutest, when I heard it on my system replacing Qute HD, I have to confess that I did not like it. The sound was aggressive, tiring and the sound stage disorganized. I could not hear records that I like very much and that I know well.
So, quite disappointed I decided to let it work 3 days in a row receiving music from the streamer and sending it to an amp of headphones ...
When I came back to listen on my system it was only for 1 hour and although better, I missed my Qute HD that I had already sold.
I returned to deoxa it to work more 4 days in a row before I heard it again, and the difference was remarkable ... Now I knew how to listen to music on my system.
All this to say that in my case did not happen practically "brain burning" ...
I can conclude that the burning that existed was indeed Qutest.
From here on, I feel like I'm getting better and better, so I think it's my brain to burn ...
I note that before having Qutest I used the Qute HD that I bought used and I also tried a used Hugo. In these two cases I liked them as soon as I heard them
Dear friends,
I will now get the chance to listen to the Qutest in my system with an InnuOS Zen so it's going to be an interesting weekend!
Would very much like to hear your thoughts on this. I'm planning on getting a Zen/Zenith and Qutest to go with my wireless KEF LS50.
Maybe I’m out to lunch, but since the wireless LS50s have built in DACs which as far as I know cannot be bypassed, won’t you just be listening to the DACs in the speakers instead of the Qutest?
You can bypass the KEF DAC.
Are you sure? Here's what Darko said in his review of the LS50 wireless:
“Purists should be made aware that all incoming analogue signals are instantly digitised to 24bit/192kHz PCM; how else would the signal be split and the left channel handed over to the other loudspeaker via Ethernet?”
Yes. Theres a follow up article on DARKO that mentions how the AD/DA conversion is very transparent and there's also threads on other websites about external dacs being used.
I personally have used the MOJO, bluesound node 2 and meridian explorer 2 dacs with the KEFs and they all sound different as you would expect.
Sorry for off topic.
