There is no off button so yesDoes everyone just leave their Qutest on all the time?
Chord Electronics Qutest DAC - Official Thread
- Thread starter ChordElectronics
Makes sense
uzi2
- Sep 27, 2013
I use an inline on/off buttonDoes everyone just leave their Qutest on all the time?
I turn the power conditioner off every night.Does everyone just leave their Qutest on all the time?
I noticed if I start playing a song when my amp is off/muted, the Qutest starts making something like static noise. I don't mean noise coming from headphones, I mean very audible, static-like noise coming from the Qutest itself.
It stops when I turn on the amp. Is this normal?
The Jester
I turn off the power conditioner when I’m going out for the day, or longer otherwise on 24/7
Triode User
Member of the Trade: WAVE High Fidelity
Yes, I leave mine on 24/7. In fact in the same system I also leave on 24/7 the Musical Fidelity amp and Innuos streamer.Does everyone just leave their Qutest on all the time?
in a different system I leave on 24/7 my Dave and MScaler together with the Antipodes K50. The power amps get turned off because they are big class A monoblocs and use significant electricity.
Chop-Top
- Jan 9, 2016
I unplug my entire system after use. Don't want to have to replace due to power surge.Does everyone just leave their Qutest on all the time?
This is really strange, I just figured out that it's actually the song playing from the Qutest as if the Qutest itself has small speakers! The sound is very distorted.
@Rob Watts is this expected?
ra990
Hahaha, this is too funny. I've never heard anything out of the Qutest, it's always been silent. I wonder where this sound is coming from? Are you absolutely sure it's the Qutest? Can you make a quick video or something to share?This is really strange, I just figured out that it's actually the song playing from the Qutest as if the Qutest itself has small speakers! The sound is very distorted.
Here's a short video: https://1drv.ms/v/s!Ap6PjUw7458BlfZg0oSfuaFKVIy13g?e=jIivTM
So this doesn't happen to you when your amp is turned off or muted and you start playing a song?
I'm using Roon with a Raspberry Pi. I also tried connecting the Qutest directly to my Macbook and same thing happens. I'm puzzled.
ra990
Definitely not. I don't have a Qutest right now, but I've had plenty of time with them and, like I said, dead silent. If you're up for it, try connecting just a simple USB power bank/battery that you might have lying around to it instead of whatever power supply you're using. If it does the same, then your Qutest definitely needs repair, otherwise it's something to do with your power supply and I would recommend just using a battery or a different PS.Here's a short video: https://1drv.ms/v/s!Ap6PjUw7458BlfZg0oSfuaFKVIy13g?e=jIivTM
Using a battery pack didn't make a change but I think I found why it's happening, it's my amp (Feliks Echo 2).Definitely not. I don't have a Qutest right now, but I've had plenty of time with them and, like I said, dead silent. If you're up for it, try connecting just a simple USB power bank/battery that you might have lying around to it instead of whatever power supply you're using. If it does the same, then your Qutest definitely needs repair, otherwise it's something to do with your power supply and I would recommend just using a battery or a different PS.
The Qutest stopped making that noise when I disconnected it from the Echo. So I tried connecting the Qutest to my solid state amp and it was dead silent. I have no idea why this is happening with the Echo, though.
uzi2
- Sep 27, 2013
Could it be why they named it Echo?Using a battery pack didn't make a change but I think I found why it's happening, it's my amp (Feliks Echo 2).
Haha I hope that's not the caseCould it be why they named it Echo?
Total: 13 (members: 0, guests: 13)
